hi im after a valve/ manifold which is leaking the garage says the threads are knackered the valve i want is just behind this one on the nearside rear but they say its the same, ive put a post on the hydraulics post to find out about it now i know what im after, ive come to sales and wants so im hoping that someone has one they can sell me im getting a bit desperate as i need my car and ive had to have quite a bit of work done on it, it seems one job leads into another so hopefully someone can help
regards john
PIC OF VALVE/MANIFOLD I NEED
juggernaut-j
Re: PIC OF VALVE/MANIFOLD I NEED
Hi John,
Sorry to hear of your re-piping woes ( I bet sometimes you wished you'd kept the Petrol one that you sold to WHM ? have you seen the new price they want for it NOW ) !
Anyhow back to the problem, from what your describing is it just the brass four way union your after (from what I can decipher from the photo) if so I may have a good second-hand one, or if you prefer a new one THIS E-bay seller has one !
Edit :- After reading the other post (And Johns comments) I see that your after a 3 way union/connector (which you hadn't stated in this post and I over looked when looking at the photo) but can look the same as the 4 way but one port has not been drilled out !
Please advise ?
Please advise ?
juggernaut-j
i was just saying the other day i should have kept the petrol one and yes i have seen the price he has done some work but not much a bit of trim a secondary rear window and for some reason the 6 cd player has gone apparently there can be different sizes 4.5 & 3.5 mm so i will have to get onto the garage monday morning
regards john
regards john
