Off topic chat about anything you like. Doesn't have to be about XMs (though they will inevitibly come up!). You can even discuss
non-Citroens
in here!
Post
by Dieselman » Sat Feb 18, 2012 10:23 am
I completely forgot about the MOT on my Mandarin car, so booked it in for this morning, ran it up the other night and found a front return pipe had split, so dealt with that.
I didn't even have time for cleaning up the spilt LHM so had some trepidation...but today it went through with a clean pass...
Happy Days...!!
Post
by Peter.N. » Sat Feb 18, 2012 12:06 pm
Well done! I have repaired those pipes just by putting the car on high suspension - I was in the north of Scotland at the time.
Post
by XMX » Sat Feb 18, 2012 1:17 pm
Well done Will ,
I bet you didn't expect any surprises, being that you keep on top of maintenance etc. meticulously with the Mandarin one !
Maybe do the pipe mod for your leak off pipes ?
XMX wrote:kenhall wrote:Using the Citroen / GSF part however would involve disturbing the LHM collector that is clamped to the strut with steel bands. I would rather leave well alone there and just replace the rubber pipe.
Ken
robert_e_smart wrote:This past while, I have kept rubber lhm returns to use to replace these leak off pipes. The handiest is the little overflow pipe that goes onto the top of the lhm reservoir cap. There is also some nice clear plastic pipe that is part of the return to the tank, and is handy for joining the new pipe into the lhm collector at the back of the strut.
I too tend go the route of a repair in stu, (Rather than disturbing the rubber saddle which is clamped to the strut/leg !
The leak off/vent pipes is a regular topic of discussion on the BXC forum, which again has been discussed this week,
Brian (Off the BXC) has done a neat modification job as shown below, note the BX has two pipes (opposed to XM/Xantias) which only have one !
Also if you did remove the saddle and are struggling to reuse the S/S securing strap or cannot get a new O/E (Kevan off the BXC) found an alternative solution by using a slightly easier type of securing strap from
THIS supplier !
If you want read thro' the BXC forum post click onto this
LINK .
The /\ quote from
THIS thread for ref. !
Post
by Dean » Sat Feb 18, 2012 1:55 pm
Well done on the pass Will, i wouldnt expect anything else from such a lovely car
Post
by robert_e_smart » Sun Feb 19, 2012 1:40 pm
Noting less to be expected indeed Will!
steelcityuk
Post
by steelcityuk » Sun Feb 19, 2012 8:31 pm
Great result, keeping the flag flying.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
