Hi Gents
Im hoping someone will be able to tell me where the abs Relay would be on a K reg 17tzd hatch.... or even better an abs wiring diagram if anyone has one to hand.
Thanks
Bx Abs
Re: Bx Abs
According to the BOL, the relay lives on the right hand side of the steering bracket
under the dash REF 756.
It's sharing space with:
blower motor max. speed relay 745
blower speed module 658
Water temp warning unit (Diesel with AC only) 87
Andrew
Andrew
Re: Bx Abs
Thank you very much Andrew.
demag
Re: Bx Abs
Err, I've never been unlucky enough to own an ABS BX
However.................I have a book with some info. It's petrol only but hopefully diesels are the same.
"ABS control unit is under the driver's seat" which must be removed for access!
The ABS diode(?) "is on the electrical wiring behind the instrument clusters." The ABS relay "is on the RH side of steering bracket".
There is an overhead map view of the car and looking at it I reckon the relay is probably clipped inside the plastic shrouds round the indicator switches. The blower motor max speed relay is in the same vicinity.
Good luck.
Good luck.
2.5td......Now sold.
BX1.6TXS
Fiat Multipla 115Elx Jtd (Not quite standard!)
Dave.
BX1.6TXS
Dave.
robertmnorton
Re: Bx Abs
Hi Dean,can't upload to this ctegory,go to "self help"
robertm
robertm
