PROBLEMS JUST AS I JOIN
TURBOd
XM newbie
Post by TURBOd »
Hi,
Just seen the forum a few days ago and as punishment, for not joining earlier, my bulletproof Green 2.1 TD is protesting. The abs sensors/system are not very happy and I need to get hold of some from somewhere. But yesterday I had a mjaor problem with my clutch pedal. The mechanism on the pedal that links it to the clutch pedal disintegrated I think its a plastic washer. Any thoughts gratefully accepted. I live in SW London and its difficult for me to take my car to parents in Lancashire to get it serviced by Malcolm at Savoy Garage. Does any one know of somebody that works on XMs?
Many Thanks
Feisal :o
Re: PROBLEMS JUST AS I JOIN
Post by Peter.N. »
Hi Feisal
Welcome to the club. Cant help you with the ABS sensors but you may find that the problem is with the plug/socket where they are connected to the loom, the front ones are inboard of the struts - follow the wires and the rear are on top of the subframe, not so easy to get at.
Your clutch problem is that the plastic link on the cable has broken, you will need a new cable I'm afraid.
TURBOd
XM newbie
Post by TURBOd »
Hi Peter,
Thanks v much for the advice. Alas I am having trouble trying to track down a clutch cable do you know anyone that might stock it. I have tried the usual suspects- GSF, Europarts and Citroen.
Cheers
Feisal
Post by robert_e_smart »
Hi Feisal,
A member on here Colin Xm (I think) makes stainless steel repair parts to replace the plastic pivot join that has broken on your car. He may be able to sort you out.
Robert
kenhall
Post by kenhall »
Feisal,
Not sure which plastic bit you are referring to but if it is the piece inside the car then the following may be of use.
Forum member jorgy had the same problem not too long ago and he managed to fabricate a metal yoke to replace the broken plastic bit. I suggest you do a search through his posts for the relevant topic.
Ken
TURBOd
XM newbie
Post by TURBOd »
Hi Guys ,
Thanks for your advice I have just emailed Colin Xm and Jorgy to ask for their help.
Cheers
Feisal
Post by XMX »
robert_e_smart wrote:Hi Feisal,
Robert
Hi Feisal, and welcome to the forum.
Robert is correct and THIS thread will be of help if Colin has any spare/ready available !
Good luck with getting the XM back on the road again !
colinxm
Post by colinxm »
Hi Feisal,
I haven't received an email from you but if this is the part that you want then email me on citxm(at)online.no as I do happen to have a quadrant left on the shelf ;-)
Cheers, Colin:p
1995 Cit XM 2,1 TD Silver Estate - deceased :-(
2004 Opel Vectra Estate
2008 Kia Ceed td
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
TURBOd
XM newbie
Post by TURBOd »
Hi Colin,
I used the email system on the forum. I will send one to your private address now.
Many thanks
Feisal :shock:
colinxm
Post by colinxm »
Ah, lots of people say they've sent emails via the forum but I rarely get them :?
Colin.P
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
