2.0 16V engine parts
Post by robert_e_smart » Sat Aug 06, 2011 11:19 am
Afternoon folks,
I have a 2.0 16V engine that came from a 1998 XM Auto (Diesel conversion car). The engine was throwing up the low oil pressure warning, and as a result the top end has gone noisy.
Anyway, there are some bits and bobs on it that my be of use to someone before I dump the engine, eg wiring harness, manifolds, injectors, throttle body, cooling pipes, rads etc etc. The auto box is not available however.
If you want anything from it, please send me a PM. But don't delay, its going to be put in the Activa shell soon.
Re: 2.0 16V engine parts
Post by citroenxm » Sat Aug 06, 2011 12:53 pm
is the autobox worth saving?
the alloy sump may be worth it to.
i always ask about awkward things or the imposible
paul
Post by robert_e_smart » Sat Aug 06, 2011 2:11 pm
Hi Paul,
The autobox is fabulous, hence it not being available :D
Its an A/C sump as well.
Post by Dieselman » Sat Aug 06, 2011 2:13 pm
Is that a cruise control modulator mounted on there? Might be useful for someone.
Post by robert_e_smart » Sat Aug 06, 2011 2:16 pm
Yup, it had cruise also. Didn't work though...
Post by citroenxm » Sat Aug 06, 2011 4:14 pm
At least yur saving the autobox....
That will be a Normal throttle cable, as its on the opposite pull to the kick down cable on the autobox....
