My old XM's
ChrisSwe
XM newbie
My old XM's
Post by ChrisSwe » Fri Jul 15, 2011 7:41 am
Sadly I don't own theme anymore. :( My TCT is still running but the 2,1TD is probably a spare part donor.
The diesel didn't pass the car inspection. The handbrake didn't work on the left side, the diesel pump was leaking (even if the workshop tried to seal it), a headlamp pointed right up in the sky and the non-working comfort spheres had a tiny drop of LHM hanging beneath (comfort mode didn't work due to surcuit break somewhere). These LHM-drops was a leak according to the inspector. Come on! It was an old and torn car with at least 350000km/35000 metric miles (218750 miles) behind. All old cars have some leaks. :evil:
I had a month to fix all these faults and... as an unemployed I had no money.
No it's no a Jaguar. It's my cat Alex inspecting the enigne room on the 2,1TD :)
Twins? No The left one became a donor car since the cylinder gascet blow away and to the right my old 2,1TD. The XM to the left was a TCT -95
My former TCT -95 (still running by a friend's mum)
But here's my present car :)
Re: My old XM's
Post by Dieselman » Fri Jul 15, 2011 4:56 pm
ChrisSwe wrote: The diesel didn't pass the car inspection. The handbrake didn't work on the left side, the diesel pump was leaking (even if the workshop tried to seal it), a headlamp pointed right up in the sky and the non-working comfort spheres had a tiny drop of LHM hanging beneath (comfort mode didn't work due to surcuit break somewhere). These LHM-drops was a leak according to the inspector. Come on! It was an old and torn car with at least 350000km/35000 metric miles (218750 miles) behind. All old cars have some leaks. :evil:
That's a shame because I doubt any of those required much money to fix and the leaking diesel pup was the only one to require much in the way of knowledge.
ChrisSwe
XM newbie
Re: My old XM's
Post by ChrisSwe » Fri Jul 15, 2011 8:29 pm
I know :( I couldn't keep her. The alternative was put her aside and wait for getting a job and renovate her. She would rather getting worse if I put her aside outdoor for at least two years. Hydractive would had been a challenge to fix. After searching and measuring the fault was somewhere under the car, in the electrical wires because the rear hydractive block didn't response and the rear magnetic valve was new.
Why the comfort spheres had a tiny drop of LHM when they not were connected as Hydractive was malfunktion, I have no idea.
