Couple of XM parts up or grabs - including matrix!
dastardly-dan
XM newbie
Post by dastardly-dan » Sat Jun 11, 2011 11:16 am
Got a few parts off my old Citroen XM up for grabs, as funds are getting quite low! All located in Hunstanton , Norfolk
Automatic gearbox - fitted to the 2.1 XUD, NOT the 2.5 (different bolt pattern I'm told) Drove onto and off of a trailer, so works. Comes with kickdown cable, and the electrical connector thingie (including the other half of the connector, and about half a foot of extra loom). Does not include the flywheel sensor
Obviously, collection only, as it still has some oil inside it, and it weighs an absolute ton! £50
Torque convertor, again, known to be good
Once again, collection only, as it's 100% impossible to fully drain these of oil £15
Flexplate/shims/etc, for above torque convertor, for 2.1 XUD
P+P may be possible - but be aware the edges of the teeth are literally razor sharp (sliced a few chunks out of my fingers when I put it down!) so I can't gaurantee it'd turn up intact... which is a PITA: £8
Or, for the gearbox, torque convetor, AND flexplate: £65
Hydraulic pump's also up for grabs
£10 collected - or £16 posted
Now a part that's rarely ever fully working - but this one is!
and even a little vieo to show no dead lines or pixels!
As you lot know, there'sa bloke currently selling these for for £200 on fleabay as NOS, so asking for £50 for a quick sale, or £53 posted
Also selling the idiot light cluster
£10 posted
Front seats - electric forwards/backwards, tilt, and on the drivers seat, up and down.
The driver seat cusion has unclipped itself, possibly just the springs losing tension due to age - easily permanently cureable with a couple of strategic cable ties! (or are they all like this??) £30 Collection only
Hydractive ECU, comes with a chunk of loom too
£10 posted
Re: Couple of XM parts up or grabs - including matrix!
Post by citroenxm » Sun Jun 12, 2011 8:44 pm
Is that a S1 dot display or S2 as they are NOT interchangeable.
S1 displays are worthless as they Never give up... S2 displays are the ones for 200 quid as on ebay..
PS your pics havent worked...
Post by Dieselman » Sun Jun 12, 2011 9:39 pm
It's an S1 display. The only one I know that gave up was mine... Typical. :lol:
Post by citroenxm » Mon Jun 13, 2011 7:29 am
Its DEFFO not worth 200 quid, Ive got about TEN of them in my shed! As they do not pack up... except for yours Will... typical. :lol: :lol:
Post by robert_e_smart » Mon Jun 13, 2011 7:49 am
They do pack up Paul...
In the '90 Sd both screens were starting to break down. One of the displays on my '90 Si (admittedly the clock) was doing the same.
Post by citroenxm » Mon Jun 13, 2011 9:05 am
And how many S1 screen have you seen pack up compared to S2's...
So that 2 then..!!
Post by robert_e_smart » Mon Jun 13, 2011 11:20 am
3!!! :D :D :D :lol:
dastardly-dan
XM newbie
Post by dastardly-dan » Mon Jun 13, 2011 1:40 pm
lol, I've exceeded my bandwidth on photobucket (will reset tomorrow!)
Car was a '92, so does that make it an S1? (never knew there was a difference!)
Post by citroenxm » Mon Jun 13, 2011 2:09 pm
Yup, well and truely a S1, almost an S1.5.. but the S1 displays do rarely give a problem at all, its only later ones. and lo and behold they are NOT a direct swap either, the pin outs are in different places between S1 and 2 displays. Id be rich if they were a direct swap.
It is however, possibly to swap all the pin feeds around to match a S1 display so I beleve...
the pin outs were documented but on which site I cannot remember at all now..
dastardly-dan
XM newbie
Post by dastardly-dan » Fri Jun 17, 2011 6:40 pm
lol, so I'm guessing at best, it's all pretty much scrap value then? :D
Pinouts would be handy - been trying to find them for a while, but it's rather difficult to find! Suprised at how much is actually lacking from the HBOL wiring diagrams....
