I've just taken the newly acquired '92 Cobalt SD for an MOT test and it failed...but only on rear lights having a slight earth fault causing dimming and o/s steering rack gaiter split.
I've ordered a gaiter kit for tomorrow and will do the rear light contacts in a minute.
I've also phoned DVLA to chase my V5 as the car still show as scrapped and they are happy the car is genuine and will remove the scrapped marker send out a V5 tomorrow.
The other red car is looking more precarious than ever as I put the jack through the cill today as the car came back down.
Nearly there with the Cobalt one..
Re: Nearly there with the Cobalt one..
Just as an aside, the brake test was interesting to see. The dials jumped straight up to a really good reading, even off the rear, much quicker and higher than other cars being tested.
Even the parking brake managed a good reading.
Good Work Will.
Is this the manual car?
They take their time!I've also phoned DVLA to chase my V5 as the car still show as scrapped and they are happy the car is genuine and will remove the scrapped marker send out a V5 tomorrow.
Keep me in mind what ever you decide to do with the Red One Will!Dieselman wrote:I've just taken the newly acquired '92 Cobalt SD for an MOT test and it failed...but only on rear lights having a slight earth fault causing dimming and o/s steering rack gaiter split.
Or have you decided to get her srted MOT'd and sold on ??
I haven't decided what to do with the mandarin car yet, I started it up to move it today and with a nearly flat battery it fired straight up.
AFAIK, it has two problems. the cills are pretty corroded, there is some rust in the o/s rear inner wing due to the tow-bar fitment and the front o/s brake calliper is seized. other than that it is pretty good to go through an MOT.
Paul, what are you looking for, parts or a complete car?
The Cobalt one is the manual...which drives very nicely even before new spheres. The visual parts of the body are the worst part of the car, everything else is very good, and I've just done the head gasket and timing belt.
The delay one the V5 has been the "scrapped" marker. They are removing this and sending a V5 tomorrow.
I don't understand why they have needed weeks to do this.The delay one the V5 has been the "scrapped" marker. They are removing this and sending a V5 tomorrow.
At least there is progress being made.
They sent me a questionnaire to send them the VIN again and engine number, on 10th May, but then nothing, hence my call today.robert_e_smart wrote:I don't understand why they have needed weeks to do this.The delay one the V5 has been the "scrapped" marker. They are removing this and sending a V5 tomorrow.
- steelcityuk
Sounds like a good result all round DM.
Steve.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
