2.1 td cam box cover
Post by Dieselman » Mon Apr 25, 2011 8:14 pm
Does anyone have a spare, good condition cam box cover from a 2.1td engine later than 1992. There was a change to the rubber seal at this age and I need the later cover, where the seal fits into a recess in the plastic.
Re: 2.1 td cam box cover
Post by robert_e_smart » Thu Apr 28, 2011 6:10 pm
Hi Will,
Is it the plastic rocker cover you're after? I have one from a 1996 car if that is of any use to you.
Post by Dieselman » Thu Apr 28, 2011 6:22 pm
Theoretically it should be depending on how the gasket fits. I want the later type where the seal fits into a groove, not the early type where it is stuck on.
Post by robert_e_smart » Thu Apr 28, 2011 6:42 pm
I'll check it out for you and report back.
