Parts for S1.
Parts for S1.
If anyone has any of the following spare I would appreciate them.
Radio aerial, possibly complete with base.
Front and rear ashtray cigarette lighter and surround.
Front o/s sidelamp, condition unimportant.
Height selector control knob or unit.
Tailgate dark smoked lighting strip.
Sunroof wind deflector spring arm and metal clamps if poss.
Glovebox gas lifters * 2
Heater control panel for rotary dial. I only need the fan speed white nylon speed control piece really.
Heater knobs * 6.
I'm sure there will be other bits as we go along.
Re: Parts for S1.
Post by robert_e_smart »
Hi Will,
I can help with some stuff. Feel free to source locally to avoid postage.
Radio aerial, possibly complete with base. These are available from Citroen, and are about £12 I think.
Front and rear ashtray cigarette lighter and surround. Yep - plain black, the front surround has holes drilled from the texalarm buttons between the two flap buttons
Front o/s sidelamp, condition unimportant. Nope
Height selector control knob or unit.Maybe, let me check
Tailgate dark smoked lighting strip. Yep
Sunroof wind deflector spring arm and metal clamps if poss. Nope
Glovebox gas lifters * 2 :lol: :lol:
Heater control panel for rotary dial. I only need the fan speed white nylon speed control piece really. Maybe, let me check
Heater knobs * 6. :lol: :lol: :lol: :lol: :lol: :lol:
Re: Parts for S1.
Has anyone got any idea how you get the manual height control out. One of mine is seized solid and after lubing it I foolishly clouted it to start it moving...only it didn't..but the top of the control knob did... :twisted: :lol:
Re: Parts for S1.
I'll add glovebox latch onto the list as well.
Re: Parts for S1.
Post by MTXM »
In response to your query on removal of the height control unit Will, ideally you need to remove the complete centre console and side panels for access and there are only a couple of 10mm bolts that hold the unit as I recall. I had to replace one recently that had a missing plastic lever end and the task is not too difficult. All the best, Matthew T.
Re: Parts for S1.
Remove the side panel and there are a couple of bolts holding it all in place. Its fairly straightforward when yoou see it. There is a bolt that holds a gear affair onto the selector rods as well. Its just pulls out with a bit of wiggling.
Re: Parts for S1.
So it's all done from inside the car?
Re: Parts for S1.
Yup.
Re: Parts for S1.
Thanks.
