Wanted Steering Ram
davetherave
Wanted Steering Ram
Post by davetherave » Tue Apr 05, 2011 4:42 pm
As above im after a non leaking steering ram please, I believe mine is fundamently rogered.
See FCF for full details!
OR would I be better buying a new one?
(87) 2.5td Cx
(01) Gpz500s
Re: Wanted Steering Ram
Post by Peter.N. » Tue Apr 05, 2011 7:16 pm
I've got one you can have if you would like to take it off the car - but we are rather a long way from Norwich :shock:
davetherave
Post by davetherave » Tue Apr 05, 2011 7:57 pm
Thanks peter, bit too far though!
Im going to put a plastic undertray on the car so the MOT man cant see the leak untill one turns up.
Dave
(87) 2.5td Cx
(01) Gpz500s
Post by Dieselman » Tue Apr 05, 2011 8:14 pm
Dave. A while ago there was a scrapyard with an XM. I can't remember where it was now but it was definitely Norfolk-ish.
Got it. http://www.dysalvage.com/
Post by MTXM » Tue Apr 05, 2011 8:52 pm
Yes Dave, the Salvage Yard highlighted by Will just south of Norwich did have a 'J' plate 2.0 non turbo that I had a few parts off. The car is probably still available and the Boss (David) would move the car if necessary and let you remove the rack and ram that should be fairly easy with that engine. I would check the price before you go and negotiate as required. Good luck and regards, Matthew T.
davetherave
Post by davetherave » Wed Apr 06, 2011 5:52 pm
Thanks ill have to check that one out. For now ill have to hope my plastic cover disguises the leak!
Hopefully ill be able to take it for a retest tomoro!
Thanks. dave
(87) 2.5td Cx
(01) Gpz500s
Post by citroenxm » Wed Apr 06, 2011 8:15 pm
Dave,
AS per FCF, if you have no luck, I may have one, and certainly one removed already if they ARE the same as Xantia ones...
