XM heating fan control unit
martinpenk
Post by martinpenk »
Has anyone got a fan control module for a 2.5td VSX estate with no air con. This is for the heater fan. Mine has just packed up. I understand a Xantia with Air con has the same module but could be reveresed polarity. Can anyone asssit. Happy to take the whole fan unit and control assembly though I do have a spare fan though I dont think the fan moter itself is the problem.
Thanks
Martin
davetherave
Re: XM heating fan control unit
Post by davetherave »
Have you tried replacing the brushes or the transistors?
These are the usual culprits.
(87) 2.5td Cx
(01) Gpz500s
martinpenk
What do you mean bythe transistors? Are these part of the control module? The fan motor itself seems OK.
Cheers
davetherave
Heres a picture of the transistors.
When mine when the motor would only work on full speed or nothing at all.
(87) 2.5td Cx
(01) Gpz500s
