Mirror housings
Mirror housings
I like the mirror housings only coloured with the rest of the plastic left black. Hmm..
Seems a bit slow to raise.
[youtube]lowsLOFGckQ[/youtube]
Re: Mirror housings
My G plater is verrrrrry slow to rise.
- jorgy
Re: Mirror housings
"meu carinho lindo" = "my beloved beauty" ,another man in love
I also like what he did with the mirror. Is this the champagne color? Very nice with the black trims and these alloys.
It needs hydraflushing, and maybe the pressure regulator re-adjusted. See how the front raises in many small steps. It should be more linear. And the suspension is definitely not giving in enough when he jumps in/jumps out. I wouldn't think it's flat spheres, it'd raise much much faster on flat spheres.
Re: Mirror housings
It sounds like the accumulator might be flat, listen to how often the pump cuts in and out again.
Re: Mirror housings
body coloured door handles too, definatly in need of some work on the suspension, without a doubt the acc sphere, filters and regulator are in a bad way.
Re: Mirror housings
thats the problem Will, the reg should not be cutting in or out at all as the pressure should not reach 175bar because it should all be leaking away to raise the suspension, they all do this when the system is not happy, mine used to.Dieselman wrote:It sounds like the accumulator might be flat, listen to how often the pump cuts in and out again.
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011 - Location: Ireland
Re: Mirror housings
Anyone else see the pool of liquid under the engine?
Ciaran
- Site Admin
5678
Re: Mirror housings
I do like the body coloured door handles, certainly works in that colour anyway, not sure it would for all colours mind...
Ciarán
Ciarán
- jorgy
Re: Mirror housings
To be precise (for readers that are not familiar with hydropneumaticsDean wrote:thats the problem Will, the reg should not be cutting in or out at all as the pressure should not reach 175bar because it should all be leaking away to raise the suspension, they all do this when the system is not happy, mine used to.Dieselman wrote:It sounds like the accumulator might be flat, listen to how often the pump cuts in and out again.
I don't remember details now as this was a few years ago, but in the black V6 I had evidence of the front struts been sticky -it's all in the write up in the other club-xm. On the green 2.1td I also had this -the lhs front would sometimes stay put (compressed) after braking, then a few secs later pop back up, couldn't believe it!! It's cured now.
As soon as it was adjusted to 145-170bar, the black V6 front would go up to position with maybe 1 intermediate "click" from the pressure regulator, other times with no click at all -just a click once in position. And we r talking of a car I got with 147k miles/230,000 killometers, and today has 175k miles/280k, and still behaves as should.
The 2.1td is still not as good, although it has improved alot compared to when I bought it; I'll be looking at the pressure regulator next and adjust accordingly to completely fix it.
In relation to all this, I never miss the opportunity to say that
1/so often I've read of people looking at their pump as the culprit for slow rising or stiff steering, when it rarelly is; it's most likely one more case of an unmaintened hydraulic system that will become again almost 100% just with a good hydraflush session! If this doesn't improve things dramatically, only then look at having a real breakdown somewhere! Note: Citroen reccommends hydraflushing as standard maintenance every 60,000 miles, and I'd not be surprised at all if Cit UK *never* has advised any UK owner of this
2/ dirty LHM tank filters have no influence whatsoever in all this!! Confirmed on both my XMs, with 2 different pressure regulator types (1- and 2-outlet type), two diffrerent steering systems (DIRAVI and DIRASS), where I only washed up the filters after the whole operation had been completed, when they were black like soot while the car had already found its full health!
George
