Window failed again but this time not the cable...
The white plastic runner that holds the window up and that the window cable slots into. It has cracked where cable end sits.
It is for a mk2 drivers door. I think it is a generic part so any mk2 door should supply one.
Is there a spare available from Citroen still?
Cheers.
Steve
Wanted: White runner for mk2 window
SteveLP
Re: Wanted: White runner for mk2 window
They are still available from Citroen dealers and AEP.
SteveLP
Unfortunately while the MK1 is available as a spare part, the MK2 version is not!Dieselman wrote:They are still available from Citroen dealers and AEP.
Citroen madness again.
So my plea for this window part is still ongoing!!
Hint hint
Hi Steve,
I'll have a rummage, I have a drivers window regulator that I am using for spares at the moment. You'll have to release the cable a bit from the winder wheel to get enough slack to get the ends into the slider. Depending on the cable condition, it may be a good time to change them.
