Help! Can't stop my headlights flashing!
- ash2020
Please someone help! I disconnected the battery this afternoon to change my seats. Now I've reconnected it and the headlights are flashing permanently. I know there's some sequence you have to do like deadlocking it , then turning the ignition with one of the dash switches pressed, patting your head then turning round three times, but I just can't remember what it is. The battery will be flat by morning if I don't sort it.
Thanks
Andrew
Thanks
Andrew
(97) XM 2.5TD VSX Green
Re: Help! Can't stop my headlights flashing!
iirc. You put the key in the ignition and turn to Ign, then press the alarm button.
- ash2020
I thought it was something like that but it doesn't work.
Have you tried the under bonnet key switch?
- ash2020
No, but I will. That might be it. Otherwise I'll just drive everywhere with the headlights on, like a Volvo, and then disconnect the battery when I stop!
Cheers
Cheers
Start the engine before holding down the alarm switch for a peiod of time.
You may need to switch off then repeat the process.
Underbonnet switch just switches the siren on and off so you may regret trying that.
minijet
The alarm/security device on these cars often goes a bit crazy after the battery has been reconnected.
The under bonnet key switch and the dash board switch have never been of any use in my experience.
I usually find that disconnecting the alarm control unit in the passenger footwell stops the immediate problem. Then I reconnect it after a day or two after everything has settled down.
I think XM's don't like a change in their routine, and get into a bit of a petulant strop if you do something different
But, my white SX has been sounding it's alarm siren a lot recently, particularly after start up in the mornings (even though I have disconnected the box in the passenger footwell
But it hasn't done it for a couple of days (fingers crossed it stays that way, or the front bumper comes off and the siren feels the full weight of my lump hammer
robertmnorton
Hi Andrew,on mine after reconnecting the battery i simply set the lock and alarm on the plip and then unlock on the plip.That resequences the alarm.The lights will stop flashing in any event in 20 mins.
robertm
robertm
- ash2020
Thanks all. Lots to try in the morning. I've disconnected the battery again overnight.
Andrew
Andrew
I was wondering what happened with that car.minijet wrote:.
But, my white SX has been sounding it's alarm siren a lot recently, particularly after start up in the mornings .
Good to hear it's back in action.
