Odds & Ends
Odds & Ends
Hi All
Picked up a couple of boxes of surplus Citroen bits today.
Started a look through and have not found much recognisable XM stuff.
I will start a list here just in case anyone recognises/wants some of it.
Most of it is NOS still in original packets.
95 566 738 - Qty 2 - think it is a Plastic Bumper fixing clip - BX?
96 140 986 - Qty 3 - 1.9D tailgate or wing flash - Stick one on the back of your V6 and really upset souped up Pug drivers when they fail to get past.
Will try to bring a few more back each time I go over to the unit.
Re: Odds & Ends
Hi All
Last night sorted through another load of bits that came my way.
Got a fair quantity of "Butee de pedale" 7572.S6
Anyone know what they are and what they fit?
There were also a few "Boitier Electro" 6105.HT
Do not look XMish.
Few more I need identified:-
1323.08 "Tuyau eau degaz"
5164.36 "Coupelle"
9164.43 "Gache serrure"
9329.T4 "Obturateur"
6552.CE "Contacteur CDE"
8580.44 "Grille"
6224.79
9165.44 "Gache serrure"
9164.30 "Gache serrure"
2403.R6 "Poignee"
95 593 245 "Bavettes G"
9033.70 "Chariotpte"
7913.35 "Charniere"
9138.C5 "Serrure PTE AR"
6555.Y6 "Bride"
9101.J3 "Poignee"
9128.N7 "Poignee"
6351.C1 "Enjoliveur D N22
9170.F0
9926.W7 "Verrou porte DR/GA"
Some more in the back of the car that I will list tomorrow.
96 419 558 80 Plastic panel (large)
7429.81 "Obtuateur"
8226.Q2 "Garnissage"
8211.C9 "Garnissage"
9023.AJ "Joint Gouttie G"
4701.56 "Levier de Frein" Handbrake lever
7603.F6 "Soparte Rueda" Spare wheel carrier
0382.Q2 "Raccard Air"
1192.WJ "Kit Rechauffeur"
1426.1V "Raccard D'Air"
6464.K8 "Tuyau D'Eau"
1307.NN "Tuyau By-pass"
1424.6E "Raccard Air"
1307.RQ "Raccard Eau"
8710.89 Boot Seal?
9023.CP "Joint Porte"
7159.07 "Enjoliveur G"
bobhalliday
Re: Odds & Ends
Post by bobhalliday »
Hi John,
if you come across a glass for the near side front sidelight gi'es a shout. Just noticed the glass missing when doing some work on the estate. I tried to pop it out to try some dodges on it but can't get to the release clip for cables, plugs and relay's, stuck some plastic over it for now. I have such a long list of to do's but the list get's longer every day. :?
Bob.
We are all Falkirk 'Bairns'
Gone, but never forgotten.
Re: Odds & Ends
Hi Bob
Will look out a secondhand sidelight for you. The plastic lense is glued to the light so they do not tend to come a spare parts.
The knack to releasing the sidelight clip by feel is to have the spare one ready so you can see where the clip is and which way to push it.
bobhalliday
Re: Odds & Ends
Thank you John.
Your kind offer would be appreciated, tell me the costs involved and I'll get it to as soon as possible. I can see and feel the clip but it's in an awkward place, full of stuff, :? but I'll leave it till I get the spare one. Don't understand why the lens would come unglued, and didn't notice it till today.
Bob.
kenhall
Re: Odds & Ends
Post by kenhall »
'Butee de pedale' = pedal stop. However neither the part number for this item nor the 'boitier electro' one are listed under Citroen service.
Re: Odds & Ends
Post by robert_e_smart »
Hi John,
I can't help you with the part numbers, but can help you with the French discriptions:
1323.08 "Tuyau eau degaz" - some type of water hose
5164.36 "Coupelle"
9164.43 "Gache serrure" - serrure is a lock, was it Cache or Gache? Cache meaning to hide.
6552.CE "Contacteur CDE" - Some tye of switche
8580.44 "Grille"
6224.79
2403.R6 "Poignee" - handle
95 593 245 "Bavettes G" Mudflaps?
7913.35 "Charniere" - Hinge
9138.C5 "Serrure PTE AR" - Rear door lock
6555.Y6 "Bride"
9101.J3 "Poignee"
9128.N7 "Poignee"
6351.C1 "Enjoliveur D N22 - wheel trim?
9170.F0
9926.W7 "Verrou porte DR/GA" Right/left door lock
Re: Odds & Ends
Found another hose this evening:
96 015 636
Still sealed in its packaging.
Think it was for a BX diesel.
