Got a few bits left on the XM
air con condensor
air con pump
windows
n/s drive shaft
most of the lights
based in ig10
few other bits, but cant remember what off the top of my head, the cars being taken away at the weekend so let me no, email address is stuartdowers@googlemail.com
XM mk1 1993
stuart1298
- andmcit
Re: XM mk1 1993
Can you let me know what state the whole exhaust system is in?
I'd fancy the cat too but you mention the downpipe?
If you're chopping that around to do an engine mod conversion can
I not swap you a mating flange downpipe?
I guess the driveshafts are spoken for?
Andrew
Andrew
stuart1298
Re: XM mk1 1993
in all honesty, i'm not sure what condition the exhaust is in, i was gonna weigh the cat in, as my local place is giving £25 a cat, but your right, its only really the mounting flange i need, the n/s shaft is there, but i have to cut the o/s shaft as it seized in, and the joint is already screwed
stuart1298
Re: XM mk1 1993
I'll be down at my garage this weekend, i can check the condition and let you no, whats ur mobile number, and i will send you a pic or 2, then i can send it while i'm there, if not i'll post it up on here in the evening
