New member with a problem
paschal
XM newbie
Post by paschal »
Hi I'm Paschal living in Ireland, owner of many Citroen cars in various states of repair.
2 non runner CX's, a good DS, and 3 XM's 1991 2.1 td, 1995 2.1td exclusive auto and my favourite a 1998 2.5 td exclusive which I drive every day.
Well used to. It's developed a really weird problem that looks like fuel starvation. It started off as a reluctance to start in the mornings, then any time now it even looses power -like a flat spot - and will even stall when idling sometimes...... and it's not really consistent. I've tried all the usual suspects including replacement of the fuel filter housing. Could the fuel pump (Bosch VP36) be the problem? any help would be very greatly appreciated
Re: New member with a problem
Post by Peter.N. »
Hi Paschal
Welcome to the club
We have several experts on 2.5s who will I'm sure will be along shortly, very nice cars but one of the reasons I like 2.1s is that you don't get these strange electronic faults, the mechanical pumps seem to go on forever.
Post by robert_e_smart »
Welcome Paschal,
Where abouts in Ireland are you?
I live near Newry. I'm afraid I'm not able to help you with the 2.5, and echo Peter's comments on the 2.1s.
Which CXs do you have?
Robert
Before going too deep insert a clear fuel pipe in the pipe run just before the injection pump and check for air bubbles.
Hi Paschal
There are two other regular air in fuel points on a 2.5TD.
The metal fuel pipes come up the engine bay bulkhead drivers side behind the engine where they change to flexible rubber pipes to come over the top of the engine. This rubber pipe splits just above the joint with the steel. Usually a very small split bulkhead side of the pipe.
The other one is the fuel heater on the end of the engine goes porus. Usual fix is to bypass the heater. Very late 2.5's got an electric heater in the fuel filter so even Citroen noticed this particular problem.
Post by XMX »
Hi Paschal and welcome,
I agree with John /\ (He beat me to it) but I suggest you also read thro' THIS thread for more info.
Also another thread showing the two type's of 2.5's fuel pipes between the fuel filter and pump (including the early thermal fuel heater [#22] and the later models [#19] which was electrical) WITHIN this 2.1 TD thread may be of help !
:D
paschal
XM newbie
Post by paschal »
Ladies and Gentlemen,
Thank you for your warm welcome. Yes the 2.1 is a fine and rewarding car and so reliable. However I must say that my 2.5s (I'm on my second) have been largely problem free except for the fuel heater by pass which is common to the 2.1 and indeed BX diesels too. Maybe I've just been lucky. I live near Trim in county Meath - come and see our wonderful Norman castle ! Aah Newry - former mecca for the southern shoppers! I frequently get to work in Dundalk which is good. Thanks too for the prompt - I shall prepare my longest pliers and hope for the best.
paschal
XM newbie
Re: New member with a problem - sol ved
Post by paschal »
Thanks for the tip. Spot on! little cracks in the supply line opening to make a big hole when bent and about 10mm from the end.
Happy days. Passed a '98 2.5 this morning. Broke down - overheating - possibly something to do with the HT on the trailer it was towing.
OK i probably would have stopped anyway just to drool but I was able to help. That does make all the other XM's in the ring run a little sweeter.....does'nt it?
Anyway thanks again. Hope I can return the favour sometime. By the way the CX's are a Mk1 2.5IE and a Mk2 2.0RE Familiale with dropped liners and its donor which is a crashed 2.2RS awaiting engine removal.
Hi Paschal
Pleased you found and sorted the leak.
CX's are a car that I know virtually nothing about.
Must have a look through the workshop manuals one day.
Good news Paschal,
Glad to hear you got sort out in the end.
You have a good selection CXs there as well. I have 2 at the moment, going to become 1, and even more spares shortly!
