Hi-new member
mike101374
Hi-new member
At last found forum for XM's. I'm on my second. First 2,1td saloon now I have 2.1td estate. Love the cars great ride. I have a good mechanic locally that looks after my car for me. BUT I do have a proble. I am on my second starter motor in 6 months. Car starts great when cold, but when hot/warm it is a swine to start. There is no turn over when I turn ignition switch. Eventually starts. Anyone had similiar problem, if so how did you fix it????
Citroen XM 2.1TD VSX automatic estate,diesel, R reg-not sure of year, blue. Lives in Suffolk near Ipswich
Re: Hi-new member
Was it the same fault for both starter motors as that sounds like a sticking solenoid or brushes problem. Try giving it a clout when it's not working.
mike101374
Re: Hi-new member
Thanks Dieselman.
Done that and it does start, just wondered if there was anyone knew of any other problem. The problem only happens when the engine has been running and then left for over 10 minutes, ie parked. Any one any ideas???
Re: Hi-new member
Hi Mike
It could be a high resistance connection on the inhibitor relay above the headlamps in the engine bay, when mine packed up it only would not start unless the car had been driven then parked up for a while, where i guess, heat soak caused the relay to loose contact, they should all be taken off and cleaned really then greased with a smear of copperslip and it should prevent any futur problems too.
mike101374
Re: Hi-new member
Thanks Dean
Are those the purple and green relays? I have just replaced all of these but did not put copperslip on them. I will give that a try and let you know in a few days time. Thanks for all the help from yourself and dieselman. I will be a regular visitor to this site. I thought I (and the misses!!!) were the only nutter who loved XM's. i AM TRYING TO KEEP MINE ON THE ROAD AS LONG AS POSSIBLE.
Re: Hi-new member
Your not alone, lots of nutters here
it would help greatly if you could edit your signature to include your vehicle details, engine size, fuel type, transmission, model year that sort of thing, it makes coming up with an answer a whole lot easier as the fault you describe could be caused by any one of a number of common things depending on engine and transmission type.
If you have replaced the relays already they may not be at fault, im not sure which colour as every model is different but pay special attention to the wiring connectors of these relays, any corrosion here will not (obviously) be cured by simply changing the relays.
glad you found us and i hope the forum proves as usefull to you as it does for the rest of us
Re: Hi-new member
Hi Mike and welcome to the club. You have the best model, as long as its manual
Check the earth connection from the battery to the engine, could be loose.
Re: Hi-new member
inside leg, favourite colour..where you live..home phone number, what you're doing on Friday night...Dean wrote:Your not alone, lots of nutters hereit would help greatly if you could edit your signature to include your vehicle details, engine size, fuel type, transmission, model year ..
Would that be enough Dean?
Re: Hi-new member
dont think what he's doing friday night is of importance D,man...............although favourite colour may be handy
mike101374
Re: Hi-new member
Hi all
Sorry for the delay in replying-wife has had me re-painting the garden sheds today-just escaped!!!
D'man -went for Indian last night (Friday) with the wife-great Indian in Wickham market, Suffolk if you are ever passing.
Once agim thanks for the advice-when I can avoid the jobs the wife got for me I will get to look at the car and check out all the suggestions-
Have added detail of signiture-
Peter N had a manaul and now an auto-like the auto best.
hope to talk soon
Mike
hope to talk soon
Mike
