Drivers side auto window switch
rayfry
I need a replacement switch for my Mk2 '95 drivers side auto window switch
Does anyone know if this is an XM only thing or does something else fit from a peugeot etc.
Ray
Ray
Re: Drivers side auto window switch
The BX used the same switch on the TZD models, try the guys at www.bx-club.co.uk (I think thats the address).
Not sure if the 605 used these larger switches.. The 306 did, but they used a different format and switch top..
xmgob
hi i'v got one i'll post it to if you give me your address thanks 01302883256.
SteveLP
Did anyone manage to replace the bulbs in these one-touch switches? I could never figure it out.
Steve
Steve
rayfry
They've got bulbs in them???
Yes. Tiny little ones, probably the same as 0.2W dashboard ones.rayfry wrote:They've got bulbs in them???
rayfry
xmgob Thanks for that.Let me know what you want for it
Ray 0161 748 7720
Ray 0161 748 7720
They are similar to Dash bulbs - but the legs are slightly longer I think IIRC...Dieselman wrote:Yes. Tiny little ones, probably the same as 0.2W dashboard ones.rayfry wrote:They've got bulbs in them???
normantilbury
Hi All,
The bulbs are 12v Lilliput lamps which maplins used to stock they come in white or green, The green ones i found where not bright enough so i ended up putting the clear white lamps in.
Its a bit of a fiddly job but not impossible my current car has most of them out so it will be a job to do when its a bit warmer, also the seat switches use the same lamps.
Regards,
Norman
Regards,
Norman
