Breaking 1994 2.5 TD
Post by robert_e_smart »
Chaps,
I have decided to break the 2.5. It has 165k on the clock, and I suspect the Head Gasket is gone. It is loosing coolant, and loads of bubbles in any coolant that is left in it.
If you need anything from it, please get in touch.
More pictures are on here, and more can be supplied if requested.
Please note that the car is wet in the pictures, and that the paint looks better than what it is in reality.
http://athena.cx/main.php?g2_itemId=2048&g2_page=2
Please note the car is in Northern Ireland.
Robert
Re: Breaking 1994 2.5 TD
Hi Robert
What are the strut heads like.
Heated seats?
Injectors and head?
ECU's etc.
All depends on carriage cost across.
Post by andmcit »
Hi Robert, I'd be interested in the silver wings, nearside rear door, nosecone and scuttle end caps if they
are straight and have at least some shine to the paint!? What seats does it have? I'm guessing I'd have to
liase with you re meeting when you're over on this side of the water... :?
Andrew
rayfry
Post by rayfry »
Hi Robert
I need drivers side window switches
Ray Fry
Hi John,
Strut heads aren't too bad. Well from what I have seen they are Ok. Just a bit of corossion under the rubber in places. I will take pictures, from above and below.
The seats aren't heated.
I don't plan on keeping any of the 2.5 specific stuff for myself, so ECUs, injectors and head etc are available.
Hi Andrew,
PM sent earlier in response to your earlier request.
Nose cone is sold.
The seats are the alcantara and velour of the early non leather exclusives. Driver seat bolster is worn, but I have a spare glovebox lid in the alcantara if you wanted to attempt a repair. The seats are grubby, but no burns or other damage apart from the wear to the drivers seat.
Davetherave has a set of these available, he'd be a lot close to you than I am.
Transport is always going to be fun. I could meet you at Dublin Port or something to make things easier, or arrange to bring them over next time I'm over on the "mainland". I suppose if there were enough interested parties, it might be worth sending a pallet over to someone.
Ray - is it the switch with the automatic function you require? This car didn't have one of those fitted, it has a standard switch in its place.
Can I also say now that I'm keeping the window regulators - with 3 XMs in the fleet, I need t hold onto these.
Robert
Passenger door mirror Robert? I assume auto dipping??
Paul, PM sent.
SteveLP
Post by SteveLP »
Do you want the working left-hand dot matrix!?
Cheers
Steve
rayfry
Post by rayfry »
Yes its the auto switch I need
thanks anyway
Ray
not wanted by myself Robert but i see there is a leccy arm rest in there.....................
