Cheap spares for XM
Cheap spares for XM
Due to the years catching up with me , I MUST reduce my stocks of new and S/H spares.
Am also currently breaking a S2 XM 2.5TD Estate and will have to scrap it soon. Get in first and do yourself a good turn!
- andmcit
Re: Cheap spares for XM
I'd be keen to buy a pair of decent 2.5 rads as spares for mine which could
give you some free space!!
What colour panelwork is available as I'm after a pair of front wings,
s2 nosecone and front headlamp washer spec bumper in burgundy - I recall
you saying you had one front wing in burgundy but cannot remember
which side you said you had = ns?
Any silver body panels, especially a nearside rear saloon door and s2
mirror shells or a black front s2 bumper!?
Andrew
Andrew
Sorry to say that I had to use a lot of what you wanted myself, but I still have the nearside front wing in "Burgundy" (KKSMR on the horizontal panel below the tangle of wiring behind the N/S headlamp) and could get it to the Wetherby Rally if you or a friend is coming there. How does a Fiver grab you? (I said things wouold be cheap)
Don't suppose you've got an o/s wing mirror in dark green have you?
1994 S2 CT auto hatch green Exclusive, SE London.
- steelcityuk
Hi Brian,
You don't have a outside (air) temperature sensor do you? Mine's gone loopy and says it's 54 degrees!
Thanks.
Steve.
Thanks.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Steve,
They aren't too expensive at the stealers as they are shared across quite a few models. More likely to last if they are new then second hand.
Rowan
I think they're in the region of £20, and as Brian says that are used in a lot of other stuff, my local stealer stocks them, as he sells a few to Xsara Pisscasso owners.
- steelcityuk
OK thanks guys - I'll check it out.
I was mainly thinking of passing trade Brians way.
Steve.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
- XM newbie
do you have a good hydraulic pump for a 2l petrol XM year 2000?
