I require the rubber seal that acts as the wiper for the drop glass and also goes under the fixed quarterlight. I've managed to split mine trying to remove it from under the quarterlight.
To remove the drop glass section the seal has to be unclipped from the barb inside the door before lifting, the quarterlight section has to be pried out sideways, as it clips under the glass.
Item 9 in image.
Wanted: Left rear door glass to door rubber seal.
