91 XM 24v LHD has landed on my drive .....
Stickfinger
Post by Stickfinger » Sat Aug 09, 2025 9:40 am
This arrived at my place on Wednesday :).....oh dear lord what is in store for me now !!!.............first inspection has it starting well, holding pressure and no leaks. Paint is a total mess but there is no rust and the undersides look very good with no welding needed but with some damage from rather poor positioning of a jack !!
Stickfinger
Re: 93 XM 24v LHD has landed on my drive .....
Post by Stickfinger » Sat Aug 09, 2025 9:42 am
Post by Dieselman » Sat Aug 09, 2025 10:42 am
With the Zender bodykit, which in itself makes it interesting.
Being a 1993 car it should have the modified engine, so no valve-train wearing out prematurely. I was aware of this car, but understood it to be a 1991 car, so would have a suspect engine.
It all appears very tidy. The headlamps will convert to Rhd by flipping the inner lenses between lamp units.
Stickfinger
Post by Stickfinger » Sat Aug 09, 2025 10:47 am
I may be wrong on the date... :)....H reg would suggest you are correct
Engine HAS the updated rockers (?) so has been done under re-call ?
Post by Dieselman » Sat Aug 09, 2025 10:52 am
Rp and engine numbers would reveal the production dates.
As long as it is modified to ceramic tappets and aluminium rockers it should be ok. The original issue was steel rockers and stainless steel tappets causing galling.
Stickfinger
Post by Stickfinger » Sat Aug 09, 2025 11:16 am
defo has the updated rockers....runs really smooth with zero tappet sounds
Re: 91 XM 24v LHD has landed on my drive .....
Post by Dieselman » Sat Aug 09, 2025 12:14 pm
There was a modification package to upgrade all the engines, but many had succumbed to wear already so were replaced with new engines.
If only I'd had space...Emerald with Zender was seriously tempting. LOL :D
Post by xantia_v6 » Sat Aug 09, 2025 2:16 pm
That looks like a good project if you can apply paint to a suitable standard. What are your plans for it?
Post by Dieselman » Sun Aug 10, 2025 7:30 am
Probably no need for paint, people are only ever going to see the back of it and that looks good... :D
Stickfinger
Post by Stickfinger » Sun Aug 10, 2025 8:30 am
A friends car.....the aim is to get it MOT'd and "roadworthy"
