xm v6 12 valve hydrulic pump removal
pj3107
Orga / RP numbers: 7437 3.0 Hatchback Auto Silver
Post by pj3107 » Tue Jul 01, 2025 9:38 am
Hi everyone
It seems my hydraulic pump appears to have a bearing failure as front/pully end of pump is getting rather hot and making the belt smoke along with a squeeking noise ( best i can explain it)
Question is there a special allen key for loosening the tension bolt or do i have to pay a vast sum to some south american surgeon to rearrange the shape of my hands to be able to get the thing loose ? :D
Maybe i am not trying hard enough but if anyone out there has taken off/ replaced the pump any advice would be gratefully received
Thanks
Re: xm v6 12 valve hydrulic pump removal
Post by Dieselman » Wed Jul 02, 2025 6:26 am
You need to loosen the locknut before attempting to turn the tensioner bolt. Access is tight, but possible.
A slipping belt will cause heat and smoke from the belt. These belts need to be very tight due to the drive and pump pulleys being smaller and the pump being driven by the cam, so the drive pulley is only half engine speed.
Ideally upgrade to a heavy duty belt and ensure it is tight: a worn belt will be sitting further down in the flanges than normal, thus exacerbating the drive issue.
Edit:
Locknut is item 32 on this diagram.
Also loosen pivot bolt, Item 30.
pj3107
Post by pj3107 » Sun Jul 06, 2025 9:19 am
Hi Dieselman
Thank You for the reply and the info
I will look to get the belt off and find a HD one to replace ... is there a brand/number I should be looking for ?
Appreciate all the assistance
Thanks
PJ
Post by Dieselman » Sun Jul 06, 2025 10:01 am
An XPZ belt is the heavy duty version of SPZ, the required length is 670mm.
pj3107
Post by pj3107 » Sun Jul 06, 2025 11:40 am
Have ordered a belt should be here in a day or 2, will le you know how I get on with it and hopefully it will solve the problem
Thanks a lot
PJ
pj3107
Post by pj3107 » Sat Jan 03, 2026 12:20 pm
Hi Dieselman
Firstly Happy New Year
Just wanted to say I did fit the heavy duty belt you recommended and all seems to be well ...no more smoke
Currently going down the Lexia 3 purchase route as the old girl does not want to run properly
Would it be possible for you to send me the wiring diagram for the 30 pin plug so I can ensure the one I purchase to go with the laptop etc actually works
Thanks for all the help
Post by Dieselman » Sun Jan 04, 2026 7:58 am
Series 2 30 pin diagnostic socket. Some options may not apply.
Xm 30 pin diagnostic socket.pdf
I believe all Fenix3 diagnostics can be read using a blink code reader connected to Ecu pin 18, which connects to the 30 pin socket, pin C1. It's possible that slow codes were deleted from later Fenix3, so this would need to be tested.
pj3107
Post by pj3107 » Sun Jan 04, 2026 10:07 am
Morning Dieselman
I see you have replied Thank You...it tells me I don't have permission to view the attached files ?? Assuming it's the 30 pin diagram ??
Post by Dieselman » Sun Jan 04, 2026 10:15 am
Strange. As long as you are logged in you should be able to download the PDF file.
pj3107
Post by pj3107 » Tue Jan 06, 2026 11:34 am
As its early 2026 i feel my full mental capacity is not fired up to date LOL
You were right i just needed to log on
Thanks for the diagram ... i will send to the Lexia vendor and see what he comes back with
Will keep you updated
Thanks
