Part No : 95666904
Southerneruk
Part No : 95666904
Post by Southerneruk »
Citroen XM
XM Steering Pipe Part No : 95666904
Southerneruk
Re: Part No : 95666904
It is the pipe that runs from the steering ram to the steering column, there are 2 of them the one I need is the bottom one on the ram which is the nearest one to the wheel arch
Citjon
Orga / RP numbers: 8032
Post by Citjon »
There should be one on the car I'm breaking, engine is out so shouldn't be difficult to remove.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
Degens
Post by Degens »
Hi, is it this.
I will then also buy the tool to get the other item off, if you still need it.
Southerneruk
I bought a ram replacement, but when fitting the pipes I damage one rounded the edges off
Degens
Post by Degens »
so, you want both, one, or also the other item. Are you at Abbot Ripton this July; I can then bring it with me, and you can decide there.
Southerneruk
How much for both or just the pipe
Would love to be at Abbot Ripton got a load of stuff that could be sold there from an estate that I broke down
Southerneruk
Are you still working on the car
Degens
Post by Degens »
Last week send the remainder (someone took off the roof and the boot) to the scrapheap, but kept a lot of stuff. Much posted on Gumtree, but I have much more not posted. Also some parts posted on ebay. I sent you a message; did you receive it?
Southerneruk
No last message mention abbot ripton
