Rain leak
newxmman
Rain leak
Post by newxmman » Sat Nov 16, 2024 8:59 pm
Passenger door, filling the inner door handle cubby cup. I cant see where its coming in, I assume door rubber anyone enlighten me on that being so?
Re: Rain leak
Post by Dieselman » Sun Nov 17, 2024 7:43 am
In my experience it will be the quarterlight window seal is leaking: The water runs down the door card into the pocket. Has your car had a door repair/replacement at some stage?
Another possibility might be the door mirror fixings leaking.
newxmman
Re: Rain leak
Post by newxmman » Sun Nov 17, 2024 3:11 pm
I dont believe the door is a replacement.
Degens
Re: Rain leak
Post by Degens » Sun Nov 17, 2024 4:19 pm
Are your drains at the bottom of the door clogged up? I have had that once, and was easily solved by unclogging; there appeared to be a high water level in the door, that spilled over and gave the impression of a leak.
newxmman
Re: Rain leak
Post by newxmman » Sun Nov 17, 2024 5:13 pm
Will check all. Cheers.
Re: Rain leak
Post by Dieselman » Mon Nov 18, 2024 7:42 am
For water to enter the inner pocket, it has to run down the face of the door-card.
