Finally found a donor for my black XM aka Fantôme Noir
Ferdinand
Post by Ferdinand » Fri Oct 11, 2024 10:13 pm
Got in touch with a guy in april who had a green donorcar for sale, but he had to go abroad foran unknown period, so he made his advert inactive and gone was the car….. Fortunately he came back last week and wrote me and I saw and bought a much needed donor for my Fantôme Noir: a Vert Vega 1998 ES9 BVM
The body is rotten in the rear, but mecanically it’s in really good shape, the exhaust is in really good condition and the interior almost perfect: All black so the headliner and carpets is going in one of my other cars.
Cars:
99’ XM 2.5 BVM Exclusive, 98’ XM 3.0i V6 BVA Exclusive, 90’ XM 3.0 V6 BVM, 97’ XM 3.0 V6 Exclusive BVM, 93’ XM 2.1 Turbo D12 BVA, Xsara 110 HDi, C3 1.6 BlueHDi, Range Rover HSE, BMW Z3, V70 D5, 144S Renault Laguna Initiale
Re: Finally found a donor for my black XM aka Fantôme Noir
Post by Dieselman » Sat Oct 12, 2024 7:24 am
Nice frilly rear arches, there.
From what I observe, the rear arches on late, Exclusive trim, Xm tend to rot badly. I believe this is a result of reduced rust protection and adding foam sound deadening on top of the rear arch liners.
The foam holds water so keeps the body wet. Due to the extra sound deadening, the cars are so quiet you can hear the tin-worm munching at the steel.
Post by xantia_v6 » Sat Oct 12, 2024 9:30 am
Are you intending to swap the BVM transmission into your car?
If so, I would recommend swapping some cogs from a diesel ML5T to lower the cruising RPM. I am always wanting a higher gear. A C5 or Peugeot with the 2.2 engine should have better ratios.
Ferdinand
Post by Ferdinand » Sat Oct 12, 2024 5:18 pm
My black XM is already a manual V6 ES9. I needed this donorcar because the slave clutch in it is dead, so no need til swap anything.. Looking so forward to getting a functioning ES9 with stick.
Cars:
Citjon
Orga / RP numbers: 8032
Post by Citjon » Sun Oct 13, 2024 3:40 pm
I found the remains of this foam when I removed the arch liners on my 98 VSX and wondered where it came from. Strangely enough the arches are pretty solid despite lots of rust elsewhere.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
Citjon
Post by Citjon » Sun Oct 13, 2024 3:48 pm
I have the parts for a RHD V6 BVM conversion, if I ever get round to it. Interesting to hear about the gearbox ratios, I will look out for one of those.
89 CX25DTR T2
72 D Super 5 Black
Post by Dieselman » Sun Oct 13, 2024 5:16 pm
I found the remains of this foam when I removed the arch liners on my 98 VSX and wondered where they came from. Strangely enough the arches are pretty solid despite lots of rust elsewhere.
I trust you did the right thing and consigned the foam to the bin.
Citjon
Post by Citjon » Sun Oct 13, 2024 8:23 pm
Absolutely, although I did consider replacing it. I'm now worried I won't be able to hear if the tin worms return!
89 CX25DTR T2
72 D Super 5 Black
