Looking for 2.0 ICV BOSCH 0280140183
bump_drft
Part # BOSCH 0280140183
2.0, injected, non-cat. They don't seem to be made anymore, nobody has them in stock. Looking for a known working used example, thank you
1990 2.0i 5-speed
Located in New Orleans, USA
Re: Looking for 2.0 ICV BOSCH 0280140183
Try playing with the last 3 digits of the Bosch p/no. I have seen 0280140 182 and 0280140 186.
I suspect the connector, or fitting bracket will be the difference, as they are just simple solenoid valves, all for Le2-Jetronic system.
The Bosch number 0280140 182 was fitted to all Peugeots and Citroens that used the1.9 litre engine Le2-Jetronic system.
The supplementary air valve is only meant to be open during cold start, but unless it has an internal temperature controlled inlet I can't see how it functions, as it has +12v supplied whenever the ignition is switched on.
See if the coil has continuity, if so, I suspect the valve inside is jammed. Maybe applying some heat might free it off, if all else fails open the case and investigate.
I wonder if it has a temperature controlled air bleed and the solenoid is to ensure the engine cuts as soon as the power is switched off, to prevent engine run on. Is it receiving +12v power and a good Gnd?
See list of direct interchange parts for BOSCH 0280140183
Factory Number
LUCAS ELECTRICAL FDB832
CITROEN 91536077
CITROEN 034545
PEUGEOT 034545
PEUGEOT 91536077
CITROEN 34545
FUELPARTS IAV035
OES 915361E007
OES 34545
STANDARD MOTOR PRODUCTS AC440
STANDARD MOTOR AC440
INTERMOTOR 14765
PEUGEOT 34545
Factory Number
CITROEN 91536077
CITROEN 034545
PEUGEOT 034545
PEUGEOT 91536077
CITROEN 34545
FUELPARTS IAV035
OES 915361E007
OES 34545
INTERMOTOR 14765
PEUGEOT 34545
I've done some research and found these are essentially mechanical devices which use a bi-metallic spring/capsule to open/close an air passage to allow fast idle for cold starts.
The electrical connection is a heating element to heat the spring when the engine is running, so check the heating element has continuity and works.
There are three versions, all similar, but Bosch no longer make them, however there are diaphragm repair kits available from https://www.missingparts.de/products/ko ... -version-3, or their ebay shop https://www.ebay.co.uk/itm/Repair-Set-f ... olid=20006
There are no heating element repair kits.
bump_drft
Oh wow thank you!
1990 2.0i 5-speed
bump_drft
I ordered that, but while I am waiting for it to get here my shop is trying a few different VW parts that he suspects might work. I'll report back if any are a working replacement.
1990 2.0i 5-speed
bump_drft
Rebuild kit does not work as the part appears dead electronically.
I would pay handomely anyone who could source me a working one, new or used.
1990 2.0i 5-speed
XM2.0SiAuto
- Orga / RP numbers: 4092
Have got a photo of the part?
1991 registered. J645BYA 2.0 Si automatic
RPO. 4092 12 April 1990
1964 Bijou project car. A complete rebuild!
Previously on here as CXprestigeauto
Citroenian XMinations columnist
Degens
Hi, I have probably the thing you are looking for. See here:
https://www.gumtree.com/p/car-replaceme ... 1491692412
I thought bump_drft has sourced a supplementary air valve, there are only three versions for all Bosch L-jetronic systems, any would probably work, though He currently has a dead engine, needing some work to resuscitate it.
The later idle control valve is different both physically and operationally.
bump_drft
Thank you, that appears different from the one I have.
We are currently trying to pull the engine on my 2.0. Some very smart friends are aiding my idiot self in making this happen.
1990 2.0i 5-speed
