The Ambassadorial XM estate has another new owner… Hi!
Ambassador JDStone
Orga / RP numbers: K475PGN Y3 2.0i Estate
That ex-ambassadorial one off YouTube
Post by Ambassador JDStone »
Hello from the newest owner of K475PGN!
It’s been fun to dig up history on Facebook, YouTube, tiktok and now this forum. I’ve not got the logbook back to see how many owners it’s had, but I’m thinking I might be number 9… maybe…
Thanks to this forum I’ve found out the car still has largely the same faults as it did a few years ago.
Even things said to have been fixed previously (Heater blower) aren’t working, so there’s still plenty to do despite the past 9 years of bills totalling to about £8000.
I’ll scour the forum with the search bar to see if I can find answers more easily than bothering everyone, but I’ll still be asking questions!
Oh and yes, I do plan on making YouTube videos with it :lol:
Re: The Ambassadorial XM estate has another new owner… Hi!
Is that 9 owners since Goeff buys cars, or just in the last 12 months?
Good luck with fixing the car up. Feel free to ask for answers to issues.
Southerneruk
Post by Southerneruk »
This that, a diesel auto estate
Ambassador JDStone
It’s a petrol manual!
So, fun thing, the steering wheel started wobbling while manoeuvering and it’s developed a rattle. 99% sure the hydraulic pump is on its way out (largely because the pulley is wobbling too!). Not quite sure how I missed that when I went to view it and drove it 152 miles home…
The best thing however is that it just happens I already have a spare from a 92 XM diesel that’s been in a box for… 13 years? Oh and the rest of the suspension system too, because I had a dream of fitting it to something else which never came to fruition… So that’s fun.
Got the Haynes manual, got the part…
Any top tips before I undertake it?
Ambassador JDStone
Oh and I got the logbook back. I really AM owner number 9. A rather good educated guess it turned out.
Quite enjoying ownership so far, plenty of small faults and the big one of (I think) the pump. Oh and rust on the crossmembers that I didn’t spot when I viewed it, but hey, it’s 32 years old, I’ll sort it. Probably.
The pump is unusual, but rust more common.
The only thing to watch for with the pump is that the suction pipe unions are tight, otherwise it will suck in air, causing erratic pressure, which you already have due to the collapsed bearing.
Ambassador JDStone
Right then, time to get on with the list! Even though I haven’t actually got my daily driver Punto on the road yet…
On the list of jobs to do:
  • Intermittent blower fan (work on all speeds perfectly fine when working)
    Clock is a blur, not fussed as I wear a watch :lol:
    The aftermarket key fob locks all doors, but drivers door & boot lock spins and the passenger side is seized.
    Boot doesn’t lock at all (shhh don’t tell anyone) but when operating the fob the boot lock does a little nudge, it gives me hope I can get the boot panel off for some experimentation and have a locking boot!
    Reverse lights don’t work, I think same for rear fog lights… again maybe boot interior panel off and wiggle things around?
    Front indicator/dogs are smashed, but I’ve got some good used ones to fit. Not sure if mine actually have fog lights installed, but the new ones do, I wonder if I can wire them up!
    Rear brakes miiiiight be sticking a smidge as when releasing the brakes from a standstill I hear and feel a very slight creak, but on the move seems fine.
    Fuel injection warning light comes on when accelerating hard or going over 60mph… apparently the car had a big injection fault and it’s been sorted but hasn’t been cleared from the ECU so light comes on anyway? That’s what I was told but I’d like more opinions on that!
There’s probably mor like gas struts and stuff…
The first “big job” will be the main hydraulic pump which is wobbly and gives notchy steering. I have a replacement refurbished pump from the same model year, 2.0i too. Owt I need to know when swapping the pump that the Haynes manual doesn’t tell me?
Ambassador JDStone wrote: Fri May 31, 2024 9:13 pm Right then, time to get on with the list! Even though I haven’t actually got my daily driver Punto on the road yet…
Blower sounds like a power feed problem, check the lead onto the fan and fuse connection. It could be the dashboard panel, but for Max speed the fan is driven via a relay, whereas all other speeds it is driven by transistors, so the fault wouldn't appear to be the actual fan control.
Circuit diagrams... viewtopic.php?f=8&t=10268
Call out if you need more specific information.
You have to push keys into Xm locks to make the lock engage with the inner unit, if the key isn't correct it just spins, likewise if the drive dogs are broken off.
Boot central locking motors can jam, often a good whack will free them off.
Reverse and rear fog lights is likely to be the wiring at the tailgate hinge is broken. Might also be the boot locking issue.
Rear brakes sticking is possible, but in my experience, it's more likely the doseur valve. Run some hydraflush through the system to clean out any sludge.
A base version won't have front fogs, making them work is possible. Not sure if wiring exists.
Efi issue, is obviously a current fault, check fault codes with a Blink Code reader. Battery disconnect will clear fault codes.
I suspect your car will have Bosch Motronic 3.1 Efi. The files are in the engine management thread... viewtopic.php?f=13&t=10588
Blink Code reader info... viewtopic.php?f=8&t=7368
There is no such thing as a big fault, just a fault.
Hydraulic pump: Just swap it over, make sure the feed pipe is tight, open the 12mm regulator bleed bolt and run for 30s to purge air, then tighten bleed bolt and all should be fine.
Ambassador JDStone
I’ve been on pump duty today… it’s gone ok until the new pump seal wouldn’t go in (see images).
I got it from eBay, saw 6.35mm in the title and thought “marvellous!”, but… it fits on the pipe fine, just not in the hole.
Having looked again they say they had limited 9mm so to expect 11mm. Should I have specified 9mm outer diameter?
Citjon
Orga / RP numbers: 8032
Post by Citjon »
Have you still got the old seal? You could re-use that for now - if it doesn't leak at first try it will probably be OK. I know you're always supposed to replace the seals but unless they are obviously damaged they are usually fine in my experience.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
