Scrapping my XM 2.1Td Exclusive (y4)
Stickfinger
Post by Stickfinger »
SOLD..............SOLD and is going to be saved...stayed in the South West
Scrapping a 2.1TD XM Exclusive.....see my posts regarding this car. Body work damage down one side due to deer.
See here to see my history/work I have done to this car viewtopic.php?f=22&t=10035
This is what it was like before:
This was the main damage.....this is now cut off and a replacement section is ready to weld in place.
Please NOTE, this is VERY IMPORTANT...due to family circumstance I DO NOT have time to spend an hour remove a £5.00 part....you are welcome to attend and remove this yourself, I may even provide a coffee :)
I will price parts as they are requested.
(I will sell the whole car and all the bits if anyone wants it for £400, it will start, rise and drive onto a trailer, brakes etc all good, no leaks).
The car was NOT WRITTEN OFF by the insurance company and did not revive any category marker.
Car was fine & passed its last MOT clean.
Rust Free car...it really is in almost perfect condition in all known corrosion areas.
Rebuilt (top end) engine with leak free Epic pump, new pulleys etc
I think the strut tops are "good"
Auto Gear Box works fine, changes smoothly
Everything worked except some pixels in the displays and a drivers door window
Citjon
Orga / RP numbers: 8032
Re: Scrapping my XM 2.1Td Exclusive (y4)
Post by Citjon »
I'm sorry to see this hasn't worked out for you, and not for the want of trying.
Hopefully someone will take it on as is and finish off the excellent job you've made of it so far.
Best regards,
Jon
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
onza100
Post by onza100 »
Hopefully it finds a good home. It has the least rust of any Xm I've seen
gwolfski
Orga / RP numbers: 5623
Post by gwolfski »
If you don't find a buyer in the end, I'll take it, I can put it in a dry shed, but I'd rather someone else take it, because I won't have time to work on a second XM for some time.
