Testing the waters - potentially looking for a 2.1td manual
Hi folks, long time forum lurker and XM aspirationalist here although I'm usually found in my BX GT or Volvo 740 turbo.
My job role is likely to change over the next month or two meaning I'll be commuting a 70 mile round trip three times a week, I'll need a diesel or perhaps LPG fuelled vehicle. My first thought was a manual 2.1 XM, are they economical enough if driven sensibly to be worth the extra maintenance over a modern? I'm also a Saab man and could quite fancy the twin turbo gen 2, 9-5 diesel. We also travel around France once or twice a year, so a diesel XM would be great for that I think.
The GT will do mid to high 30's mpg wise and the 740 is not quite yet finished, but did high teens/low 20s before it was a turbo (the turbo should improve the mpg as it was quite underpowered) but I wouldn't really want to regularly commute in either.
If i were to be picky I'd want an early, top spec, manual 2.1 in black with black leather and air conditioning but what are the chances!!
If anyone has an XM for sale or knows of one, I may well be interested.
Thanks
Thanks
- Orga / RP numbers: 4937
Re: Testing the waters
I'd say a 2.1td XM will be economical enough even if you drive it like a lunatic!
Over a 35 mile commute, i reckon you'll see high 40s if not more.
- Orga / RP numbers: RP 8603
What are the advantages of an 'early' 2.1?
I would have thought that as late as possible would be a better starting point (if only because you get the advantage of minor improvements in the design and build along the way) - although I suppose how it's been maintained and stored + distance travelled will outweigh mere age...
Thanks guys. I much prefer the looks of a series 1/1.5, same as with BX's - the MK1's are much more 'Citroen'.
Basically no engine electronics (if it has the bosch pump), only has a wire for the shutoff solenoid and the glow plugs. So ease of repair. I believe the later 2.1s were the same core engine but with more electronics to control them.
1992 2.1 TD Estate, in green
I have an auto 2.1td .. however I drive it with the kickdown/load sensor cable disconnected from the throttle.. firstly this makes the car give a return of Round 46mpg on a run... it does however make the gearbox change up at set road speeds, but this is advantageous as it gives the better mpg, with the kickdown cable on the engine ends up just revving away at 3k and the torque is never used...
Avoid a 2.1 from 1996 onwards if the lucas epic is fitted. The best setup is the S1.5s and early s2 cars with bosch mechical pumps.. the bosch pumps are long lived and last longer should IT NEVER see any veg.. ours hasn't, and is now on 269k with no pump leaks...
Manuals are rare, most were auto.. the autobox demands maintenance and DEX 2 fluid changes every 15k should see a long life, it did on ours..
I will have a 1994 L reg top spec SEi manual available soon however, shes a V6 .. not a td..
Something to bear in mind.. s1 cars only got cruise control on autos, and petrol engines only, but s2 exclusive 2 1td auto also got cruise control, part if the s2 equipment upgrade.
The issue in the UK with later cars, and any really, is poor body .. later cars seem to suffer under body rot worse then any early car...DownUnderXM wrote: ↑Fri Nov 17, 2023 4:00 amWhat are the advantages of an 'early' 2.1?
Thank you for an excellent answer citroenxm! I was aware of the epic pumps and the need to avoid, but I'm pleasantly surprised at the auto mpg. Perhaps I don't need a manual?
In general driving a 2.1td auto will consume more fuel than a manual, however, due to utilising a longer final drive ratio and full torque converter lock-up, when on a steady cruise an auto can return mpg as good as a manual.
Keeping the boost gauge reading below half way really helps with fuel consumption.
You will be lucky to find a Series1, 2.1td manual for sale, let alone in black, or high level trim.
I won't be that fussy! Just in an ideal world etc. Nothing is set in stone yet either but as I've always fancied an XM this might he ab ideal opportunity- if I can find one of course
