Hi has anybody got i think is m16 fine thread nut for strut top, or tell me if m16 x 1mm pitch thread is correct for the small dia strut tops that fit
1996 2.0 16 v
Thanks
Tim
strut top nut m16 very fine thread
Timcol
- Orga / RP numbers: RP 7183
Series 2
2.0 16v Sx
1997
Re: strut top nut m16 very fine thread
It is M16 x 1mm thread.
All Series 1 Xm used that 23mm size strut. The later 25mm strut, 18mm thread iirc, was introduced on the heavier Series 2 Xm, starting with the 2.5Td.
With appropriate, matching, strut tops the struts are interchangeable as the actual piston size didn't alter.
Timcol
Series 2
2.0 16v Sx
1997
Thanks again for your help
Tim
Tim
Timcol I think I can spare one if needed...
Let me know..
Let me know..
