Ecu n bits
Ecu n bits
Any of this of interest to anyone.. ?
Very early suspension ecus ...
A plastic keyed keypad
Idle valve
Ignition amp
I've also some v6 12v prv ecus but don't know the codes
Also a couple of fenix 4 24v v6 prv ecus also unknown codes..
If no interest they will go in the scrap pile. They are no use to me either.
Idle valve
Ignition amp
- Orga / RP numbers: 8032
Re: Ecu n bits
Hi Paul,
I'd be grateful of the idle valve if you're just going to bin it.
Possible future project for my DS21 fuel injection!
I don't mind waiting if you're OK to bring it to a rally.
Many thanks,
Jon
Many thanks,
Jon
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
89 CX25DTR T2
72 D Super 5 Black
Re: Ecu n bits
Hi jon .. yea cool no problem.
Re: Ecu n bits
Is this to be a carburettor to injection project, or is the car already fuel injected?
If a conversion, I would pick one of the injection systems from either a 1.9Bx, or 2.0i Xm, probably the Magnetti Marelli G5, as that is distributorless.
As long as the system has a knock sensor the timing should advance the timing until the start of knock is detected then hold it just back from there.
Though if you fit a Motronic 3.1, it automatically uses the Lambda sensor feedback as mixture regulation.
- Orga / RP numbers: 4937
Re: Ecu n bits
I'll take a suspension ECU please, Paul
I wouldn't hurt for a run out your way, rather than you having to post it. Anything else people want collecting, I'll happily drop off anywhere between Paul's and east Cheshire, or within a half hour's drive of Macclesfield
Re: Ecu n bits
Do you want a h2 black ecu Julian?
Re: Ecu n bits
If it'll work with h***bkj, yes please, Paul
Re: Ecu n bits
Yes should do.. it was a black h2 car
Re: Ecu n bits
Mondays are the best day for me to collect at the moment. Does either the 20th or the 27th suit you, Paul?
Re: Ecu n bits
Yes either so 20th?
