Bits missing to complete Interior Refurb
Saraphi
Orga / RP numbers: 6834
Post by Saraphi » Thu Nov 10, 2022 5:36 am
I've changed seat covers to leather/alcantara, also door cards, have fitted pale gray headlining and almost all the roof fittings to gray.
Really happy with the way the interior has lightened up.
There are just 6 niggles that I'd like to get right before I publish photos in all their splendour, they are:-
The front grab handles in light gray (4 pcs)
The nearside front door fittings in Hurricane
Can anyone help please?
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Re: Bits missing to complete Interior Refurb
Post by Dieselman » Thu Nov 10, 2022 7:55 am
Note to anyone with grab handles.
These apper to be the post 1992, lighter grey, not very early ones.
Seraphi, is it just the front grab handles and shells you are looking for, or front and rear. I'm slightly confused by your request for 4 pieces.
Saraphi
Post by Saraphi » Fri Nov 11, 2022 2:53 am
front only = 2x handles, 2 x Shells = 4 pieces?
1 x door handle surround + 1 x Speaker cover = 2 pcs , total 6.
You are quite right about age and colour!
Thanks
Post by citroenxm » Sat Nov 12, 2022 8:03 am
I have the handles but they are in a dirty state .. dont know if they will clean up. I was changing my project car to black any grey I had I didn't respect. If dieselman is correct the grey in my 1994 (if its still fitted) should be the correct shade.
I can check Monday as I'll be with the car .. I have loads of the handle surrounds and speaker grills but they are all black. Didnt realise there was a grey sort too
Post by Dieselman » Sat Nov 12, 2022 9:33 am
The grab handles only come in two shades of grey, darker shade pre-'92, lighter shade post-'92.
The speaker grilles and interior door handle surrounds are all hurrricane grey, apart from pre-'92, which are black.
It's difficult to see the difference between black and huricane grey, one can only see it with two pieces side by side.
Post by citroenxm » Mon Nov 14, 2022 1:32 pm
Hi .. I've recovered the front grab handles and backing trim from this 1994 car which is light grey.
The handles will need a clean before fitting ...
XM2.0SiAuto
Orga / RP numbers: 4092
Post by XM2.0SiAuto » Mon Nov 14, 2022 7:26 pm
I may have the grey grille and surround.
1991 registered. J645BYA 2.0 Si automatic
RPO. 4092 12 April 1990
1964 Bijou project car. A complete rebuild!
Previously on here as CXprestigeauto
Citroenian XMinations columnist
Post by citroenxm » Thu Nov 17, 2022 11:09 am
Right.. I've unearthed a collection of handles. And here is difference in attached pics. There is a shame difference but also one has a dint down it while the other is all smooth..
So which do you want the smooth or the one with the lines to match the ones you have?
Strangely, I've also come across a smooth finish handle surround, with the groove in it but only one at the moment, so that means theres 3x designs
Post by citroenxm » Thu Nov 17, 2022 1:35 pm
I also have a handfull of speaker grills to compare. But I've run out of energy for today..
