series 1 wheel trims
ex-em
Post by ex-em »
im after some series one wheel trims, anybody got some for sale? they flush ones with little flap for air filler ,seen the ones on ebay but they are bit expensive!!! :oops:
please email me mitsi-czc@hotmail.co.uk
thanks all
Re: series 1 wheel trims
Let me see what I have, But Im sure ive not got any, just a set of Series 2 trims - that clip onto thewheel nuts..
ex-em
Post by ex-em »
thanks
what are the series two ones? have you a pic? i plan on removing alloy wheels and just using wheel trims i dont like alloys!!! i hope to be getting a series two but wasnt aware they came with wheel trims!!! and i do like the flat look of the series 1
cheers
Post by robert_e_smart »
Hi ex-em
They're Mine,
Let me try and see if I can get the postage price reduced.
Send me your best offer by Private Message here (not on e-bay), and I'll review it.
If anyone else can supply ex-em with the same wheeltrims, please feel free.
Thanks
Robert
PS - Series 2 trims below
Hi All
Do not forget that those Mk1 & Mk2 steel trims you are talking about use different wheel bolts.
Hi folks,
Yes, the series 1 uses a shorter wheel bolt head than the series 2.
But if ex-em is going from alloys to steels, he will need steel rim bolts anyway.
Robert
ex-em
Post by ex-em »
pm sent,
i presume that if i get steel xm wheels from a series two then series on trims would be fine?
thanks
Hi
Yes, steel rims stay with their bolts as alloy rims stay with their bolts, early alloys had a flat head not the later taper style bolt but that shouldnt be of concern as your going to steels, also mk1 steelie bolts stay with mk1 trims and longer mk2 bolts stay with mk2 trims, the heads a different.
that was yes to mk 1 or 2 rims accepting any trim by the way :oops:
ex-em
Post by ex-em »
thanks
so would i need series one wheel bolts with the series one trims or could i just use series two? (yes im a bit thick :roll: )
