diagram
Southerneruk
diagram
I need an exploded diagram of the Brake Meter and the part before it that connected to the brake pedal
Re: diagram
https://catalogs.ssg.asia/citroen/?lang ... BwbGllcj09
https://catalogs.ssg.asia/citroen/?lang ... aWVyPT0%3D
Southerneruk
Re: diagram
Thanks, that is a great help Dieselman, trying to find out why brakes are binding
Re: diagram
Brake doseur valve removal and free play adjustment (9mm) is covered comprehensively in the Haynes manual.
Southerneruk
Re: diagram
Pulling all apart, I think I might have found the problem, the pivot bolt/screw was very stiff with rust, got it all moving now need to reline top bolt adjuster with the right gap
Re: diagram
If it hasn't been adjusted previously it should still be set correctly.
I trust you have only removed the doseur valve/bell crank bracket.
Don't be tempted to pull the rubber gaiter out, it's a real pain to refit in the lower steel skin properly and will cause the bell crank to press on the doseur valve if not in correctly.
Re: diagram
Glad you found it.. I had said pivots will be siezing up theres little else to cause itSoutherneruk wrote: ↑Sat Oct 15, 2022 1:32 pmPulling all apart, I think I might have found the problem, the pivot bolt/screw was very stiff with rust, got it all moving now need to reline top bolt adjuster with the right gap
Re: diagram
Pack the pivot with grease to stop a repeat.
