wanted
Southerneruk
wanted
Front brake calipers for a 2.1 TD estate on a k plate (92) both sides
Re: wanted
Why do you need these?
If they are sticking either push the pistons out and clean them up, or run hydraflush through the system.
If binding on it may well be the doseue valve isn't fully returning to the off position, so holding slight pressure in the brake pipes.
