FDV and V6 hydraulic pump
Hi all
I am looking for a known good FDV, don’t care about leaks, or which model it is from as I will fit new filters, seals and set steering supply pressure, but don’t want something that looks like it has been dredged off the seabed please.
Also, looking for a V6 12v/24v hydraulic pump with the later larger pulley wheel (100mm? Not the earlier 88mm?) don’t mind the condition.
Many thanks
Many thanks
Re: FDV and V6 hydraulic pump
I have a V6 Pump (Xantia V6) but it would come with no guarantees, I would say it needs to be rebuilt.
I think any Xantia V6 pump wuold be the multi-ribbed 6+2 type.
Dean is looking for an original seven piston pump, with the later 100mm pulley.
My suspicion is that the larger pulley is an attempt to stop belt slip. I have seen a bulletin that the larger pulley was fitted to reduce the pump speed, not belt slip.
Bx were fitted with the same 86mm pump pulley.
OK....np
I think the bed solution regarding belt slip would be to fabricate an idle roller on the slack side of the belt, to give the belt a longer contact with the pulley.
This is an addition I may perform.
Ask.!!! Ive Still got loads of bloody v6 pumps.. And a decent poking fdv to hand too..
Have you a. Pully diameter you want..?
Hi Paul
Thought you had sold it all on! Would like the larger one, they are around 100mm diameter, if you have one that would be great. I will msg you later.
OK there's 2x v6 pumps here both have around 108mm pullys on them...
And fdv
Still loads of starters for v6.. Coolant pipes.. Some front exhaust link pipes front bank to rear..
V6s all gone now only have a 2.1td auto project and a S2 2.1 auto exclusive
And fdv
