Offers welcome
A/C Compressor
A/C Condensor
A/C Reciever Drier
Hydraulic Fluid Tank
O/S and N/S brake calipers
O/S and N/S auto drive shafts. if i can manage to get the hub bolts out
Bits i'm not sure what they are
Some sort of abs/hydraulic pump
ECU for the above
pump attached to gear box with hydraulic pipes in to it
XM mk1 air con bits
stuart1298
jonathan_dyane
Re: XM mk1 air con bits
Where are you Stuart? I may be interested in the driveshafts...
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
stuart1298
My cars in Loughton Essex, having trouble with the hub nuts, gonna get my mates gun on it one night this week and see if they will undo it, as i managed to bend my breaker bar today,jonathan_dyane wrote:Where are you Stuart? I may be interested in the driveshafts...
jonathan_dyane
Alas, that's rather a long way from me, and I would wager they'll be dear to post, which I can't really justify as my inner joints are just starting to make a slight noise (probably a good few tens of thousands of miles left if I regrease them (but will I get round to it
Thanks anyway!
Thanks anyway!
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Johnathan,
Have you drive shaft problems?? Ive a fair few here in the shed lying about, Im sure theres some 2.1 td shafts, however, I think the shafts are more gearbox related rather then engine related..
jonathan_dyane
Not yet, but I suspect I will need at least one in the future. Good to know you have some lying around, I suspect all 4HP18 cars would have the same driveshafts.citroenxm wrote: Have you drive shaft problems?? Ive a fair few here in the shed lying about, Im sure theres some 2.1 td shafts, however, I think the shafts are more gearbox related rather then engine related..
Cheers,
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Johnathan
PLEANTY of spares here!! ALWAYS ask you never know what I maight have, when I car comes in and has its fate decided nothing is wasted!
Im up to my EYES in Xantia parts at the moment too, but the XM side is also CRAMMED full!
