Con rod nuts.
Mutly
Orga / RP numbers: ZPJ4 fitted in a Renault Alpine
Con rod nuts.
Post by Mutly »
Anyone know where I could get some con rod nuts for an XM ZPJ 3ltr. V6 engine...& also crankshaft thrust washers @ 2.3mm.
Re: Con rod nuts.
I thought you found obtained nuts and bolts from the Delorean suppliers, but said the nuts were regular high tensile ones.
For thrust washers an engine rebuilder, or Delorean spares would be my first thoughts.
Mutly
Re: Con rod nuts.
Post by Mutly »
The only person with thrust washers is Simon-auto.de & they want 99 euro plus carriage for a £15 set of washers...the nuts I found on the Delorean site are for the 2.8 odd fire...they do not have parts for the 3ltr as it was never fitted to their cars...ALL the parts I,ve tried to source are NO longer available...I had to get Total seal make a set if piston rings...which makes rebuilding these engines or any ZPJ ,Z7X a nightmare.
