Bits and bobs
Bits and bobs
Hi all.
Long time since I've posted here since I swapped asemi functioning Xm for a rusty Ds!
Now clearing the shed and garage of remaining xm parts so will update the list below before trying eBay with all the bits I find and try and get some pictures once I work out how to on the phone!
3293.03 9621434980 new original Citroen/peugeot cv boot kit x2
3293.96 as above x1
3293.02 as above x1
Strut tops mostly knackered ? Good to send off and be refurbed.
6pk1736 new belt Dayco
6pk1710 new belt dayco
6pk1130 new belt dayco
1109.n3 new citroen oil filter x2
Vff155 new fuel filter motaquip
Grey sunroof swith and light surround
S2 glovebox lock mechanism
Bendix abs ecu 9600011280
Used turbo d badge
New silver insert trim see picture
Door lock switchs x5 three with back bit see pic
Windscreen wiper arm
Top Battery bracket
Ubd n65628 new brake caliper
Two starter motors
Valeo alternator cant make out part number
Lots of blower motors
Valeo 2541193 alternator x2 ?v6
Lots of switches
12v vacuum pump
3.5 litres of comma dexron 2 atf fluid
Update more later
3293.96 as above x1
3293.02 as above x1
Used turbo d badge
Top Battery bracket
Two starter motors
Lots of switches
12v vacuum pump
Update more later
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
Re: Bits and bobs
can we see the underside of. the strut tops.. upside can still look good when knackered it's the underside that's important.
how. much are your blower motors.?
Re: Bits and bobs
Below are the large diameter struts undersides.
Reckon one pair you might trust whilst awaiting a set to be refurbed, but i have not cleaned up etc to see how bad they are. Last 2 pics are of the best strut top of the 9 which i would trust on a car Hope that helps....!
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
Re: Bits and bobs
and how much are blower motors. those bottom two look very good. how much gold you looking for.?
Re: Bits and bobs
5 quid each for the blowers. Here is a pic as they are not all the same i.e can't promise they are all xm!
Had a loose idea about it being a good stock to do an exchange system but time life etc....
10 quid each for the"good tops" and a fiver each for the duds.Had a loose idea about it being a good stock to do an exchange system but time life etc....
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
- sageman
Re: Bits and bobs
Could someone please advise on whether any of these strut tops are good for my car
I remember reading something about the amount of dots but can't remember the details thank you
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Re: Bits and bobs
without seeing. your tops with. the nut off the top its very hard to tell I think.
I've a better gamble. as I have selection of struts I can match to them to fit to a car.
Re: Bits and bobs
All the tops Dave has are larger ones for S2 cars.
Your car will have smaller ones, unless they have already been swapped.
From memory, the thread on smaller ones is 16mm, larger ones, 18mm.
