Wanted trims
Xoán
Orga / RP numbers: 8416
Wanted trims
Post by Xoán » Thu Dec 03, 2020 12:27 am
I need these two pieces arrowed in red.
2000 XM 2.5 TD Blue Mauritius.
Previous: 1993 XM 2.1D Grey.
Re: Wanted trims
Post by White Exec » Thu Dec 03, 2020 7:19 am
Are you needing those two as blanks, or as the working items (cancel interior sensors, and red LED) ?
Xoán
Re: Wanted trims
Post by Xoán » Thu Dec 03, 2020 12:22 pm
As blanks. No alarm in my dk5.
Re: Wanted trims
Post by Dieselman » Fri Dec 04, 2020 7:14 am
Contact Marc61 or EthanR. They are breaking S2 Xm.
Re: Wanted trims
Post by xantia_v6 » Fri Dec 04, 2020 7:39 am
UK cars generally all had alarms due to the silly Thatcham rules imposed by the insurance companies. The rest of Europe was not saddled with that and alarms and deadlocking were rarely fitted, so you will probably need to look to continental Europe to find the blank covers.
Re: Wanted trims
Post by White Exec » Fri Dec 04, 2020 7:51 am
By coincidence, Rex (Saraphi)'s post today contains an Ebay link, and if you scroll down you should see this item...
Citroen Xm Y4 Switches Buttons
sold by marciusxm
Seems to include the blanks.
https://www.ebay.co.uk/itm/Citroen-Xm-Y ... 0047.m2108
Re: Wanted trims
Post by citroenxm » Sat Dec 05, 2020 7:46 am
The square blank (2nd from right is available in the uk when cruise was not fitted) but so far I think every uk S2 Y4 xm had alarms on them so the end on isnt..
Re: Wanted trims
Post by White Exec » Sat Dec 05, 2020 11:40 am
Square blank here...
https://www.garage80.nl/en_GB/a-4818854 ... xm-type-2/
I bought a BX steering wheel from them recently. Immediate dispatch and as-new item.
You could just ignore the tiny red LED fitted to the end position; it's more-or-less a blank filler anyway . . . or make use of it for something entertaining ;) .
Xoán
Re: Wanted trims
Post by Xoán » Sat Dec 05, 2020 2:28 pm
Thanks.
djg
Orga / RP numbers: 7903
Re: Wanted trims
Post by djg » Sun May 23, 2021 9:29 pm
Is it still needed? Mine had the blanks but I retrofitted CC and put my alarm led there. I must still have the blank (I think the double one). I can look if needed. Pity I didn't see this topic back then when new. :-)
Bye,
Gábor
