Hi
I’ve decided to scrap my car, after nearly 10 years of enjoyable motoring. It’s just failed the MOT on bad rust to the sills and a big hole in the structure near the fuel tank and offside rear jacking point. I’ll be stripping it of useful stuff, so if there’s any S2 stuff you’re looking for just le me know.
Car is top of range W reg 3 litre but with 5 speed manual box. Silver, black leather, early S1 alloys, S1 window motors etc.
Cheers
Marc
S2 V6 parts
marc61
S2 V6 parts
About 8 XMs, now all deceased
Re: S2 V6 parts
I would like a pair of front side lights, and (if in good condition) a silver rear bumper. The complication is that my XM is in France but I am currently in New Zealand, and there is no prospect of an early return to the northern hemisphere.
Just remembered, I would also like spares of the 2 flexible hydraulic pipes that run from the engine to the subframe.
David Hallworth
Re: S2 V6 parts
Hi Marc,
How much do you want for the engine, gearbox, wiring loom, radiator, top hose, bottom hose, mounts and drive shafts?
Thanks,
David.
Thanks,
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Re: S2 V6 parts
Awwww what a shame to read this Marc after all the work we put in to convert to manual.. is she really not worth patching up.
It was a learning curve converting though I must say..
marc61
Re: S2 V6 parts
PMs sent
Agree it’s a shame Paul, but the rust is pretty bad, it’s rusted from the inside out so the tank needs to be taken out and the sill/floor cut out which is a bit too major for me.
Cheers
Marc
Cheers
Marc
Rommel
Re: S2 V6 parts
Very interested in the Hydractive ecu Marc.
Also what shape are the front struts and tops in?
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
ES9 V6
Previous:
2.5TD VSX Estate
marc61
Re: S2 V6 parts
Not sure about the struts, they look ok but I’ll take them off and find out.
PM sent
PM sent
On the understanding that these would transfer from S2 to S1:-
Front subframe, as the one on the 24v is rust with a bit of metal attached to it. Goes without saying that it must be solid as it will be sandblasted before fitting.
13th window and fittings
Sound deadening on the engine bay firewall
Front wheel arches
Picture of the alloys?
Does this car have a sunroof?
Front wheel arches
Re: S2 V6 parts
The esj subframe is different to S1 in a couple of places
Alloys same as yours..
I've got 13th windows...I think. Well did have..
I've archs set aside for you too..
