Front Silencer RGX engine
XMnation
Post by XMnation »
Just a request any one got a front silencer for an RGX engine? One straight after the cat. I've put a request and question :roll: :roll: :roll: in the petrol section too just in case.
Ian :?:
XMnation
Re: Front Silencer RGX engine
Post by XMnation »
Just an update on the silencer. I bought a 16v one and it is virtually the same but as I feared the connector to the cat is a couple of inches longer. It fits every where else so I have an option to take it to a Tyre and Exhaust shop to get the front part cut and re welded. It was a a chance worth taking as the exhaust is an Citroen genuine one.
If you want to install it yourself you could cut it down and use a connector sleeve as the joint.
As there is no availability of the correct part, this sounds like the way forward. Thanks for the information.
