Gasa XM 2.1 "Prestige"
Gasa
Orga / RP numbers: BX 1.9 TRD
Re: Gasa XM 2.1 "Prestige"
Post by Gasa » Tue Apr 25, 2023 7:52 pm
Today I experimented with the relays, they all work and have power, the fans work one, two, high and low speed.
But it all works when I give them contact manually, now I know which relay is for what, they don't stand on their bracket, so they were mixed up.
The two green ones are for turning on the fan, this black one is for the speed.
I numbered them to know which relay turns on one fan which turns on two.
...when I give them the ignition manually, everything works as it should both when the engine is turned off and when it is turned on.
...so everything works manually, but still when it reaches the temperature it won't turn on the fans, I also directly connected the shielded plug from the temperature sensor, nothing happens.
What gives the command to start the fans.
Gasa
Post by Gasa » Wed Apr 26, 2023 6:10 am
...it seems that the problem is with this Bitron, it has control on the fans, these days I will replace it and see if there are any changes.
https://www.google.com/url?sa=i&url=htt ... AdAAAAABAP
Post by Dieselman » Wed Apr 26, 2023 6:58 am
It could be.
The Bitron box shunts the Gnd side of the relays to Gnd to make them operate on Bitron unit, Pin 1 and Pin 10. (Relays Pin 2) You will see +12v at the connections until the Bitron unit switches the relay on, then the conenction will shunt to Gnd,
Is that happening, if not, is there power and Gnd to the Bitron unit.
Batt +ve is Pin 4
Ign +ve is Pin 15
Gnd is Pin 3.
It could be the sensor is U/s. I don't have the resistance values, but see if it reads similar to the blue and green ones for a given water temperature.
Like you, I would think disconnecting it might well turn the fans on as a fail-safe mode.
Gasa
Post by Gasa » Wed Apr 26, 2023 8:30 pm
...problem solved, I opened the box to the driver's side to check the Bitron, the connector was pulled out of the Bitron, now everything works, the fan turns on when the air conditioner is turned on, and when the engine reaches 90 degrees.
...thanks Dieselman for the detailed advice.
Post by Dieselman » Thu Apr 27, 2023 7:03 am
No need for thanks, the best thank you is for you to have this Xm back on the road, while improving your own skills.
Gasa
Post by Gasa » Tue May 02, 2023 7:50 pm
... some small problems, sometimes it turns on the STOP lights, sometimes it doesn't, I knew the problem was in the contact, I removed the switch and cleaned the contacts with sandpaper, so far it works fine.
I had a problem with the cable, the connector of the switch, the "experts" from Citroen fixed the problem that the connector could not be pushed through due to the screw being unnecessarily long, I solved the problem by cutting the cable and connecting it with a clamp.
..the problem is with screw , which is very long and the connector cannot go through because of it.
...you can see how burnt the contact is.
..and modification for easier contact removal,behind the pedal there is a place to put it.
Post by Dieselman » Wed May 03, 2023 6:50 am
That pedal arm fixing is very different to a Rhd one, where there is no issue removing the pedal switch.
To stop arcing of the contacts there should really be a capacitor mounted in parallel, to act as a suppressor, obviously it was decided that it wasn't required.
Gasa
Post by Gasa » Thu May 04, 2023 7:30 pm
Registered today, technical inspection millet. :)
Post by Dieselman » Fri May 05, 2023 6:18 am
Good to see, now it's drive time.
Nice early Bx there as well, Gasa.
Gasa
Post by Gasa » Fri May 05, 2023 8:20 am
I've been driving the BX for 20 years, now it's going to rest a bit, it's safer for me than the XM, there's nothing to break on it, there's nothing from the electronics. :)
