headlight washers
Re: headlight washers
Inside the binnacle are two caps. Remove these then the two screws, lift or prise the rear edge of the unit upwards, where it meets the warning lights diaplay, then once it is clear, pull the binnacle rearwards, towards you.
vive la difference
Hi Dieselman
Many ,Many thanks for the information, Easy when you know how!!, Instrument pod removed, and broken end of the speedo cable, plastic connection cable to speedo is broken but i think i can effect a repair, Just need to source the new inner cable!
Regards Brian
Regards Brian
citroen xm S1 v6
Range Rover P38 4.6 HSE
Alfa Romeo 147
Alfa Romeo 147
davetherave
Sorry its taken a while!
Heres the pics of my current stock, really need to get round to making more before the molds break!
by right hand side I assume this is O/S?
£12.50 inc P+P
Dave
£12.50 inc P+P
Dave
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
vive la difference
Hi Dave
Thank you for your reply, Yes please 1 no offside,ie RH SIDE (DRIVERS SIDE )
Dave i will be out of the country from tonight for apprx 1 week, If possible you could e.mail with payment details and i can organise before my departure
Regards Brian
Regards Brian
citroen xm S1 v6
Alfa Romeo 147
Alfa Romeo 147
