Wanted - AC pipes and door
- steelcityuk
Re: Wanted - AC pipes and door
Sorry for the late reply. That sounds great. Are you having a whip round for the fuel?
Thanks.
Steve.
Thanks.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Be aware though, the red door on a S2 car is Magenta, not Mandarin.
- steelcityuk
Hi DM,
I need to check this out and find out exactly which colour my car is. I just assumed it was Madarin.
Thanks.
Steve.
Thanks.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Yours is Mandarin, series 2 cars are Magenta.
The colour code is on the inner wing behind the n/s headlight. Mandarin is code EJV.
If I'd know you were after a door I would have saved it, though it wasn't 100%.
- steelcityuk
Not to worry. Maybe I should try harder at getting to grips with spray painting.
Steve
Steve
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
normantilbury
Hi, Try these people http://www.edwardsandson.co.uk/about-edwards-a-son.html
if they have one i can bring it up to you when i come up to Huddersfield to see the family and for the northern rally.
Regards,
Norman
Regards,
Norman
I think you could master the spray painting without too much trouble Steve.
Practice does make perfect, and spraying is only a small part of the process. Its the easy part. The preparation is the killer and where the quality of results will stem from, and I am confident that you could get good results.
