2.5 clutch
marc61
2.5 clutch
Post by marc61 » Wed Dec 10, 2014 5:50 pm
Would anyone have a spare or know how to replace the plastic fitting which clips onto the 2.5 clutch pedal and transfers the movement to the master cylinder?
It's the plastic equivalent of a rose joint but less sturdy and mine is worn and drops off when it feels like it - clutch pedal hits the floor etc etc :cry:
About 8 XMs, now all deceased
Re: 2.5 clutch
Post by xmexclusive » Wed Dec 10, 2014 7:20 pm
Replaced the cylinder and pipe assembly in one of mine a few months ago.
Had a recovered complete pedal box on the bench as a guide to what I had to do contorted under the dash.
What came out was not a Citroen cylinder so suspect I used the cylinder and rose on the swap.
Will have a look to see if I can find anything spare over the weekend.
marc61
Re: 2.5 clutch
Post by marc61 » Sun Dec 14, 2014 3:25 pm
Hi John, would you know if the plastic rose unscrews from the rod that transfers movement to the master cylinder, or is it all one piece?
I took the steering wheel assembly out so I could see it a bit better. Managed to keep the rose from pulling itself off by fitting a couple of cable ties to constrain the rod relative to the pedal arm when the pedal is pushed. A bodge, will have to see how long it lasts.
Cheers
Marc
