It's different to the 2.1td, but I suspect all 2.0-8v use the same pipe, as afaik, the regulator doesn't move location from manual to auto.
If really stuck, Pleiades could probably make one for you.
I've checked.
The 2.0 petrol and 2.1 diesel do use the same pipe, but only for automatic gearboxes.
The manual boxed versions use different length pipe to the auto and each other.
I'll look up all the pipes.
thay makes sense as the 2.0 manual uses a be3 box and 2.1td manual, uses the larger M series box so I'd suspect the regulator sits is a different place..
Having looked again I see the 2.0 petrol and 2.1td pipes are different part numbers, but the length for the 2.1 isn't listed, so technically the only pipe that will fit is the one for the 2.0i Auto.
See attached list
See attached list
Citjon
- Orga / RP numbers: 8032
That is really helpful, thank you. Pleiades is probably my best option in view of this.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
89 CX25DTR T2
72 D Super 5 Black
Morning Citjon
If you are looking for the HP pump to distribution valve supply pipe, I think I have one. I will have a look later and get a photo for you.
Citjon
Morning Dean,
Yes that would be great if you have got one.
Many thanks
Many thanks
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
If that fails, it looks like these people might have some.
http://130.226.11.57/cgi/mp?eng%A496027353
Alternatively, pleiades, or a local hydraulics specialist may be able to make one for you. 6.35mm is 1/4" pipe.
Citjon
Made a bit of progress over the last few days. Front panels refitted but will need adjusting to get the gaps something like.
Nice day for a test drive!
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
That appears to be in great condition...and nearly ready for the road.
